Edge Software Catalog
473 討論
FAILED: load BTF from vmlinux: Invalid argument
rangshaonan
初學者
12,907 檢視
When i build core-jammy   of intel ECI following the https://eci.intel.com/docs/3.0.2/getstarted/building.html,  it will build fail, i found the fail log :
GEN modules.builtin
LD .tmp_vmlinux.btf
BTF .btf.vmlinux.bin.o
LD .tmp_vmlinux.kallsyms1
KSYMS .tmp_vmlinux.kallsyms1.S
AS .tmp_vmlinux.kallsyms1.S
LD .tmp_vmlinux.kallsyms2
KSYMS .tmp_vmlinux.kallsyms2.S
AS .tmp_vmlinux.kallsyms2.S
LD vmlinux
BTFIDS vmlinux
make[3]: *** [/<<PKGBUILDDIR>>/Makefile:1186: vmlinux] Error 255
make[3]: *** Deleting file 'vmlinux'
make[3]: Leaving directory '/<<PKGBUILDDIR>>/build-full'
make[2]: *** [Makefile:219: __sub-make] Error 2
make[2]: Leaving directory '/<<PKGBUILDDIR>>'
+ exit 2
make[1]: *** [debian/rules:42: override_dh_auto_build] Error 2
make[1]: Leaving directory '/<<PKGBUILDDIR>>'
make: *** [debian/rules:28: build] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
How to resove this issue?
標籤 (1)
0 積分
1 解決方案
Lay
員工
12,299 檢視
The issue can be solve with below:
Build core-jammy image manually following these steps:
# cd /home/user/eci3/230912/edge_controls_industrial/Edge_Controls_for_Industrial_3.0.2/Edge_Controls_for_Industrial/release-eci_3.0.2/Edge-Controls-for-Industrial/eci-release
# export  KAS_BUILD_DIR=/home/user/eci3/230912/edge_controls_industrial/Edge_Controls_for_Industrial_3.0.2/Edge_Controls_for_Industrial/release-eci_3.0.2/Edge-Controls-for-Industrial/eci-release/build/eci-core-jammy
# [optional] $ sudo KAS_CONTAINER_IMAGE=jammy-kas-isar:3.0.2 ./kas-container --git-credential-store ${HOME}/.git-credentials clean
# vim build/eci-core-jammy/tmp/work/eci-jammy-amd64/linux-intel-rt/5.15.49-rt47-5/git/scripts/link-vmlinux.sh +233
The patch is https://github.com/intel/linux-intel-lts/commit/b775fbf532dc01ae53a6fc56168fd30cb4b0c658. Please add the lines in above file.
if [ "${pahole_ver}" -ge "124" ]; then
         extra_paholeopt="${extra_paholeopt} --skip_encoding_btf_enum64"
fi
# KAS_CONTAINER_IMAGE=jammy-kas-isar:3.0.2 ./kas-container --git-credential-store ${HOME}/.git-credentials build targets/kas/eci-core-jammy.yml
在原始文章中檢視解決方案
11 回應
JesusE_Intel
主席
12,853 檢視
Hi rangshaonan,
Could you please share the specifications (CPU, Storage, Memory) for the system you are using to build core-jammy image? Please note that this task requires a lot of resources, and the system should meet the system requirements.
https://eci.intel.com/docs/3.0.2/getstarted/requirements.html#linux-build-system-optional
I am in the process of building core-jammy image from my side, I will let you know if I encounter any issues.
Jesus
rangshaonan
初學者
12,662 檢視
Hi, Jesus
Sorry so late replaying, because the chrome browse couldn't replay this post.
I've found that this is not an issue with the computer's specifications.  Please see this
https://devkernel.io/posts/pahole-error/ , this post has resolved my problem.
But I have some other questions again.
1、when I disabled the CONFIG_DEBUG_INFO_BTF configuration option, the build will report an error:
42762 /<<PKGBUILDDIR>>/samples/bpf/bpftool//bootstrap/bpftool btf dump file /<<PKGBUILDDIR>>/build-full/vmlinux format c > /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h
42763
42764 /<<PKGBUILDDIR>>/samples/bpf/bpftool//bootstrap/bpftool btf dump file /<<PKGBUILDDIR>>/build-full/vmlinux format c > /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h
42765 Error: failed to load BTF from /<<PKGBUILDDIR>>/build-full/vmlinux: No such file or directory
42766
42767 Error: failed to load BTF from /<<PKGBUILDDIR>>/build-full/vmlinux: No such file or directory
42768 make[7]: *** [Makefile:157: /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h] Error 2
42769
42770 make[7]: *** [Makefile:157: /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h] Error 2
42771 make[6]: *** [/<<PKGBUILDDIR>>/samples/bpf/Makefile:293: /<<PKGBUILDDIR>>/samples/bpf/bpftool/bpftool] Error 2
42772
42773 make[6]: *** [/<<PKGBUILDDIR>>/samples/bpf/Makefile:293: /<<PKGBUILDDIR>>/samples/bpf/bpftool/bpftool] Error 2
42774 make[5]: *** [/<<PKGBUILDDIR>>/Makefile:1871: /<<PKGBUILDDIR>>/samples/bpf] Error 2
42775
42776 make[5]: *** [/<<PKGBUILDDIR>>/Makefile:1871: /<<PKGBUILDDIR>>/samples/bpf] Error 2
   The problem is that I don't know which script calls this "bpftool btf dump file /<<PKGBUILDDIR>>/build-full/vmlinux format c > /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h" and why call this.
2、There is no "pahole" in the Docker container jammy-kas-isar:3.0.2. But when compiling the image, the link-vmlinux.sh can found the "pahole" with path "/usr/bin/pahole" which version is v1.25, how did this program come about, and how can its version be controlled?
3、By specifying this option --skip_encoding_btf_enum64 , the image will be created. But when it is running, the kernel reports an error:
[ 4.421228] BPF: [112814] ENUM netdev_tx
[ 4.421944] BPF: size=4 vlen=3
[ 4.422640] BPF:
[ 4.423317] BPF: Invalid btf_info kind_flag
[ 4.424014] BPF:
[ 4.424689] failed to validate module [nfnetlink] BTF: -22
rangshaonan
初學者
12,710 檢視
rangshaonan
初學者
12,662 檢視
Hi, Jesus
42763
42766
42769
42772
42775
[ 4.422640] BPF:
[ 4.424014] BPF:
rangshaonan
初學者
12,662 檢視
Hi, Jesus
42763 42764 /<<PKGBUILDDIR>>/samples/bpf/bpftool//bootstrap/bpftool btf dump file /<<PKGBUILDDIR>>/build-full/vmlinux format c > /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h
42766 42767 Error: failed to load BTF from /<<PKGBUILDDIR>>/build-full/vmlinux: No such file or directory
42769 42770 make[7]: *** [Makefile:157: /<<PKGBUILDDIR>>/samples/bpf/bpftool/vmlinux.h] Error 2
42772 42773 make[6]: *** [/<<PKGBUILDDIR>>/samples/bpf/Makefile:293: /<<PKGBUILDDIR>>/samples/bpf/bpftool/bpftool] Error 2 42774 make[5]: *** [/<<PKGBUILDDIR>>/Makefile:1871: /<<PKGBUILDDIR>>/samples/bpf] Error 2
42775 42776 make[5]: *** [/<<PKGBUILDDIR>>/Makefile:1871: /<<PKGBUILDDIR>>/samples/bpf] Error 2
[ 4.422640] BPF:
[ 4.424014] BPF:
rangshaonan
初學者
12,700 檢視
rangshaonan
初學者
12,677 檢視
Hi, Jesus
Please read the content on the image.  !_!
rangshaonan
初學者
12,662 檢視
Hi, Jesus
Sorry so late replying, because chrome browser couldn't replay this post.
I've found  this is not an issue with the computer's specifications. Please see
https://devkernel.io/posts/pahole-error/ This post resolved my problem.
But I have some other questions again:
1、When I disable the CONFIG_DEBUG_INFO_BTF configuration option, the kernel will output the following error:
42763
42766
42769
42772
42775
2、There is no "pahole" in the Docker container, but when building core-jammy image , the link-vmlinux.sh can found "pahole" with path "/usr/bin/pahole" which version is v1.25,  how did this program come about, and how can its version be controlled?
3、By specifying this option --skip_encoding_btf_enum64, the core-jammy image will be created,buf when it is running, the kernel reports an error:
JesusE_Intel
主席
12,656 檢視
Hi rangshaonan,
Let me check with the development team on these issues you are encountering. We will respond to you shortly.
Jesus
Lay
員工
12,300 檢視
fi
JesusE_Intel
主席
12,124 檢視
回覆
