Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
IGH EtherCAT master
zhangbbbb
We have installed the IgH ethercat master Stack with the command "sudo apt install eci-softplc-fieldbus" or "sudo apt install ighethercat ighethercat-dkms ighethercat-examples ecat-enablekit", but an accident——Starting EtherCAT master 1.5.2 modprobe: FATAL: Module ec_master not found in directory /lib/modules/5.19.0-32-generic
failed——occurred when we started ethercat master with command "/etc/init.d/ethercat start"
JesusE_Intel
Hi zhangbbbb,
What kernel version are you using (please provide the output of uname -a)? Did you install ECI Real-time linux kernel? If not, please install the Linux Intel LTS PREEMPT_RT kernel per the instructions: https://eci.intel.com/docs/3.0/getstarted/installing_packages.html#install-eci-real-time-linux-kernel
Once installed, reboot the system and boot using the new kernel. You can confirm using uname -a and you should see intel-ese-staandard-lts-rt+ in the output. Then run /etc/init.d/ethercat start.
Jesus
JesusE_Intel
Hi zhangbbbb,
Jesus
JesusE_Intel
