Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Ingestion Doesnt auto reconnect when stream is broken
kranthi_volteo
We are seeing some issues with ingestion not able to reconnect when stream is broken/down temporarily. Everything works if I restart container manually.
"/VideoIngestion/config": {
    "encoding": {
      "type": "jpeg",
      "level": 95
    "ingestor": {
      "type": "opencv",
      "pipeline": "rtsp://localhost:8554/live.sdp"
Also tried with different ingestor - gstreamer.
WengWai_C_Intel
Hi @kranthi_volteo ,
Can you provide more info regarding the scenario you are having on your setup?
1) How the stream is broken? RTSP camera disconnected (turnoff)?
2) Or the camera still up running but it doesn't have the stream running?
3) Roughly how long the duration for the stream disconnected before it resume?
Meantime, when you run with opencv ingestor, can you add the "loop_video=true" into the VIdeoIngestion config through the ETCD webUI (example as below) and try with you scenario?
kranthi_volteo
Hi Weng,
     I am currently using virtual RTSP stream. May be just couple of seconds when  stream disconnected, as I can see in VLC stream works perfectly fine.
WengWai_C_Intel
Did you try add the loop_video setting with opencv ingestor per suggestion earlier? Please let us know, thanks!
kranthi_volteo
Hi Weng,
     No, I can try but, we are not using file to loop, we are directly using rtsp stream URL in our pipeline.
WengWai_C_Intel
The loop_video for opencv will trigger retry if the stream disconnected. Therefore, suggest you to try with this config to check on the scenario you are seeing. Please let us know once you have a chance to try it.'
thanks!
