Edge Software Catalog
472 Discussions
Inquiry about ECI's EtherCAT Enablekit Component and Source Code Availability
hz0908
I am keenly interested in ECI's EtherCAT Enablekit component, particularly in the parsing of ESI and ENI files and the functionality related to EtherCAT network configuration. While I have come across mentions of source code in the ECI documentation, I am still unclear about whether the source code for features like ESI and ENI file parsing is accessible through apt installation.
Could you please clarify if ECI's EtherCAT Enablekit provides the actual source code for functionalities such as ESI and ENI file parsing when the component is installed through apt, or does it solely offer related APIs and example programs without disclosing the implementation details? Thanks alot.
Iffa_Intel
You can find what you are looking for in the source code.
Download ECI source code per the instructions Download ECI — ECI documentation (intel.com).
Then, look in ~/release-eci_3.0.2/Edge-Controls-for-Industrial/eci-release/targets/layers/meta-intel-fieldbus/meta-eci-fieldbus-isar/recipes-ethercat/ecat-enablekit/ecat-enablekit
Cordially,
Iffa
Iffa_Intel
ECI typically offers a standard setup for activating EtherCAT, and the EtherCAT stack is designed to utilize DKMS for constructing kernel modules, typically sourced from locations outside the kernel source tree.
You can locate the source code for the EtherCAT stack at: /var/lib/dkms/ighethercat-dkms/1.5.2/source. The default EtherCAT stack configuration resides in a file called dkms.conf, allowing for customization as required.
You may refer to this documentation for further details.
For the ESI and ENI, you may refer to the EtherCAT Enablekit Sanity Checks section in the documentation.
Generally, the example is installed through apt and the executable will be placed in /opt/ecat-enablekit which then can be run with ESIfile.xml or ENIfile.xml.
The steps provided only cover examples on how to do sanity check using ESI and ENI and any custom implementation requires customization from your side.
Cordially,
Iffa
hz0908
Thank you very much for your response. However, I assume that the source code path you mentioned, "/var/lib/dkms/ighethercat-dkms/1.5.2/source," likely contains the code from the open-source EtherCAT master station, i.e., igh. According to the EtherCAT Enablekit architecture diagram in the ECI documentation, at the application layer, the ESI file is generated into an ENI file using a configuration tool. Subsequently, based on the information described in the ENI file, the user-layer library of ighEtherCAT is invoked for bus configuration and data communication.
Therefore, I would like to confirm whether the source code implementation for the ESI -> configuration tool -> ENI -> LibEcat part is accessible. I appreciate your assistance.
Iffa_Intel
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
