Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Install Edge Insights for Vision - Multi-Camera Detection of Social Distancing installation failure
Sudarshan
******@******:/home/local/AAPL/ydixit/EII2/edge_insights_vision(1)/edge_insights_vision$ sudo ./edgesoftware install
Please enter the Product Key. The Product Key is contained in the email you received from Intel confirming your download: ******-******-******-******-******
Starting the setup...
ESB CLI version: 2021.4
Target OS: Ubuntu 18.04
Python version: 3.6.9
Checking Internet connection
Connected to the Internet
Validating product key
Successfully validated Product Key
Checking for prerequisites
All dependencies met
-------------------SYSTEM INFO--------------------
Package Name: Edge Insights for Vision 2021.4.2 LTS
Product Name: System manufacturer System Product Name
CPU SKU: Intel(R) Core(TM) i5-7600 CPU @ 3.50GHzScreenshot from 2022-01-27 15-28-25.png
Memory Size: 16 GB
Operating System: Ubuntu 18.04.6 LTS
Kernel Version: 5.4.0-96-generic
Accelerator: None
CPU Utilization: 5.5%
Available Disk Space: 148 GB
Starting installation
Downloading modules...
Downloading component esb_common
ZIP file for module 5e8c4742e02f17002a2a6976 already exists. Validating it...
Module validation passed for 5e8c4742e02f17002a2a6976
Skipping download...
Downloading component Amazon_Web_Services_Greengrass_Prerequisites
Failed to download the module Amazon_Web_Services_Greengrass_Prerequisites. 404 Not Found
Downloading component K3s_Lightweight_Kubernetes
Failed to download the module K3s_Lightweight_Kubernetes. 404 Not Found
Downloading component Azure_IoT_Edge_Prerequisites
Failed to download the module Azure_IoT_Edge_Prerequisites. 404 Not Found
Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime
Failed to download the module Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime. 404 Not Found
Downloading component Deep_Learning_DL_Streamer_Pipelines
Failed to download the module Deep_Learning_DL_Streamer_Pipelines. 404 Not Found
Downloading component Docker_Community_Edition_CE
ZIP file for module 5f21392e9e63c9002a6fd88d already exists. Validating it...
Module validation passed for 5f21392e9e63c9002a6fd88d
Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Container
Failed to download the module Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Container. 404 Not Found
Downloading component Docker_Compose
ZIP file for module 60e327614c1e9d002a6d6a7a already exists. Validating it...
Module validation passed for 60e327614c1e9d002a6d6a7a
Downloading component edgex_foundry
Failed to download the module edgex_foundry. 404 Not Found
Downloading component RI_MultiCamera_Social_Distancing
Failed to download the module RI_MultiCamera_Social_Distancing. 404 Not Found
Downloading modules completed...
Installing shared module 'esb_common'
Unzipping the shared module 'esb_common'...
running install
running bdist_egg
running egg_info
writing esb_common.egg-info/PKG-INFO
writing dependency_links to esb_common.egg-info/dependency_links.txt
writing top-level names to esb_common.egg-info/top_level.txt
reading manifest file 'esb_common.egg-info/SOURCES.txt'
writing manifest file 'esb_common.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-x86_64/egg
running install_lib
warning: install_lib: 'build/lib' does not exist -- no Python modules to install
creating build/bdist.linux-x86_64/egg
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating 'dist/esb_common-0.1-py3.6.egg' and adding 'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing esb_common-0.1-py3.6.egg
Removing /usr/local/lib/python3.6/dist-packages/esb_common-0.1-py3.6.egg
Copying esb_common-0.1-py3.6.egg to /usr/local/lib/python3.6/dist-packages
esb-common 0.1 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.6/dist-packages/esb_common-0.1-py3.6.egg
Processing dependencies for esb-common==0.1
Finished processing dependencies for esb-common==0.1
Successfully installed shared module 'esb_common'.
Modules to be installed by package are ['Amazon_Web_Services_Greengrass_Prerequisites', 'K3s_Lightweight_Kubernetes', 'Azure_IoT_Edge_Prerequisites', 'Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime', 'Deep_Learning_DL_Streamer_Pipelines', 'Docker_Community_Edition_CE', 'Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Container', 'Docker_Compose', 'edgex_foundry', 'RI_MultiCamera_Social_Distancing']
Failed to install Amazon_Web_Services_Greengrass_Prerequisites due to missing file
Failed to install K3s_Lightweight_Kubernetes due to missing file
Failed to install Azure_IoT_Edge_Prerequisites due to missing file
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime due to missing file
Failed to install Deep_Learning_DL_Streamer_Pipelines due to missing file
Docker_Community_Edition_CE is already installed. Type YES to reinstall or NO to skip installation.
NO
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Container due to missing file
Docker_Compose is already installed. Type YES to reinstall or NO to skip installation.
NO
Failed to install edgex_foundry due to missing file
Failed to install RI_MultiCamera_Social_Distancing due to missing file
Installation of package complete
| Id | Module | Status |
| 601c2f303eb151002ace2c3b | Amazon Web Services Greengrass Prerequisites | FAILED |
| 60e4a1ae4c1e9d002a6d6ae7 | K3s Lightweight Kubernetes | FAILED |
| 605c6e6c5a4b53002c272655 | Azure IoT Edge Prerequisites | FAILED |
| 6194d607ff6f230021e4382d | Intel Distribution of OpenVINO toolkit 2021 4 2 Runtime | FAILED |
| 6194d65fff6f230021e4383a | Deep Learning DL Streamer Pipelines | FAILED |
| 5f21392e9e63c9002a6fd88d | Docker Community Edition CE | SUCCESS |
| 6194d81eff6f230021e43848 | Intel Distribution of OpenVINO toolkit 2021 4 2 Container | FAILED |
| 60e327614c1e9d002a6d6a7a | Docker Compose | SUCCESS |
| 60e58a224c1e9d002a6d6b1e | edgex foundry | FAILED |
| 6194da61ff6f230021e43865 | RI MultiCamera Social Distancing | FAILED |
Sahira_Intel
Hi Sudarshan,
Are you installing EIV on a fresh Ubuntu installation?
Sincerely,
Sahira
