Edge Software Catalog
488 Discussions
Installation failed for intelligent traffic management and edge insight vision
CHEEHOO_K_Intel
Hi.
I tried to install intelligent traffic management and edge insight vision but failed.
For edge insight vision, the installation was hanging at the installation of AWS GreenGrass. I have to press Ctrl-C to skip it after waiting for almost one hour. After that when it continued to install Docker, another error popped out. The screen capture of the log is as follow:
Installed /usr/local/lib/python3.6/dist-packages/esb_common-0.1-py3.6.egg
Processing dependencies for esb-common==0.1
Finished processing dependencies for esb-common==0.1
Successfully installed shared module 'esb_common'.
Modules to be installed by package are ['Amazon_Web_Services_Greengrass_Prerequisites', 'Azure_IoT_Edge_Prerequisites', 'K3s_Lightweight_Kubernetes', 'Intel_Distribution_of_OpenVINO_toolkit_2020_4_Runtime', 'Deep_Learning_DL_Streamer_Pipelines', 'Docker_Community_Edition_CE', 'Intel_Distribution_of_OpenVINO_toolkit_2020_4_in_a_Container', 'Docker_Compose', 'edgex_foundry', 'ONNX_Runtime', 'Azure_IoT_Edge_Setup', 'Multi-Camera_Detection_of_Social_Distancing']
Installing Amazon_Web_Services_Greengrass_Prerequisites
Installing AWSGreenGrass                           [.....                                             ]  11%  00:00:08
^C
WARNING: Setup aborted by user
Failed to install Amazon_Web_Services_Greengrass_Prerequisites took 51 minutes 41.17 seconds
Installing Azure_IoT_Edge_Prerequisites
[sudo] password for kch:
Configuring the Environment                        [..................................................] 100%
ERROR: Failed to update packages
Failed command: sudo apt-get -y update
Failed to install Azure_IoT_Edge_Prerequisites took 23.80 seconds
K3s_Lightweight_Kubernetes is already installed. Type YES to reinstall or NO to skip installation.
Skipping re-installation for K3s_Lightweight_Kubernetes
Installing Intel_Distribution_of_OpenVINO_toolkit_2020_4_Runtime
Installing OpenVINO and its packages               [..............................                    ]  60%  00:00:01
Failed command: sudo apt -y update
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2020_4_Runtime took 7.75 seconds
Installing Deep_Learning_DL_Streamer_Pipelines
ERROR: Failed to install: OpenVINO. Please check the OpenVINO version
Failed to install Deep_Learning_DL_Streamer_Pipelines took 0.05 seconds
Installing Docker_Community_Edition_CE
Verifying if docker is installed                   [..................................................] 100%
Installing Docker                                  [........                                          ]  16%
E: The repository 'https://packages.microsoft.com/ubuntu/18.04/multiarch/prod bionic Release' does not have a Release file.
E: The repository 'https://apt.repos.intel.com/openvino/2020 all Release' does not have a Release file.
Failed to update packages Docker CE
Failed to install Docker_Community_Edition_CE took 7.16 seconds
Installing Intel_Distribution_of_OpenVINO_toolkit_2020_4_in_a_Container
Stopping OpenVINO Containers                       [..................................................] 100%
Building Docker image. This step may take approximately 5 mins.
Building docker image                              [..........................................        ]  85%  00:00:06
ERROR: Failed to build Docker image Openvino
Failed command: sudo docker build -t openvino/ubuntu18_runtime:2020.4 .
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2020_4_in_a_Container took 44.22 seconds
Installing Docker_Compose
Please check docker services on the target device and try restarting the docker daemon.
Failed to install Docker_Compose took 1.33 seconds
Installing edgex_foundry
Installing EdgeX. This step may take approximately 5 mins.
Installing EdgeX                                   [.................................                 ]  66%  00:00:00
Error:Failed to build docker image
Failed command:sudo -E docker-compose pull
Failed to install edgex_foundry took 1.19 seconds
Installing ONNX_Runtime
Error:Failed to install: OpenVINO. Please check the OpenVINO version
Failed to install ONNX_Runtime took 0.07 seconds
Installing Azure_IoT_Edge_Setup
Failed to install Azure_IoT_Edge_Setup took 5.92 seconds
Installing Multi-Camera_Detection_of_Social_Distancing
ERROR: Failed to install: OpenVINO 2020.4. Please check the installed OpenVINO version
Failed to install Multi-Camera_Detection_of_Social_Distancing took 0.05 seconds
Installation of package complete
|            Id            |                            Module                            |  Status |
| 5f213bae9e63c9002a6fd88f |         Amazon Web Services Greengrass Prerequisites         |  FAILED |
| 5f213c3b9e63c9002a6fd890 |                 Azure IoT Edge Prerequisites                 |  FAILED |
| 5f4c9405e02ae6002a7d29f2 |                  K3s Lightweight Kubernetes                  | SUCCESS |
| 5f2867ae4fc424002ac30328 |    Intel Distribution of OpenVINO toolkit 2020 4 Runtime     |  FAILED |
| 5f286b834fc424002ac3032a |             Deep Learning DL Streamer Pipelines              |  FAILED |
| 5f21392e9e63c9002a6fd88d |                 Docker Community Edition CE                  |  FAILED |
| 5f2868714fc424002ac30329 | Intel Distribution of OpenVINO toolkit 2020 4 in a Container |  FAILED |
| 5f213aae9e63c9002a6fd88e |                        Docker Compose                        |  FAILED |
| 5f21411d9e63c9002a6fd898 |                        edgex foundry                         |  FAILED |
| 5f286c7a4fc424002ac3032b |                         ONNX Runtime                         |  FAILED |
| 5f21457b9e63c9002a6fd89b |                     Azure IoT Edge Setup                     |  FAILED |
| 5f46568d5fac2e002a88590d |         Multi-Camera Detection of Social Distancing          |  FAILED |
Out of all the modules, only K3s Lightweight Kubernetes was successful.
For Intelligent Traffic Management, the installation failed at docker installation as well:
Modules to be installed by package are ['Docker_Community_Edition_CE', 'Docker_Compose', 'Intel_Distribution_of_OpenVINO_toolkit_2020_4_in_a_Container', 'Intelligent_Traffic_Management']
Installing Docker                                  [.............................                     ]  58%
E: The repository 'https://download.docker.com/linux/ubuntu bionic Release' does not have a Release file.
Failed to install Docker CE repository
Failed to install Docker_Community_Edition_CE took 26.91 seconds
Failed to install Docker_Compose took 1.26 seconds
ERROR: Docker dependency check failed.
Failed command: sudo docker ps
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2020_4_in_a_Container took 0.02 seconds
Installing Intelligent_Traffic_Management
Failed to install Intelligent_Traffic_Management took 0.02 seconds
| 5f464c425fac2e002a885907 |                Intelligent Traffic Management                | FAILED |
Attached files are the logs for  both installation.
Platform: Atom E3950, 4gb memory, Ubuntu 18.04.5.
Chee Hoo
CHEEHOO_K_Intel
I tried to install on another platform with i5-8400 64gb ram Ubuntu 18.04.4 but I am still getting the same error. I have configured my proxy and apt-proxy and tried to install using sudo su as well.
Nadia_J_Intel
Hi Chee Hoo,
Can you try them on Ubuntu* 18.04.3 LTS. Kernel 5.0 instead ? This is the requirements for both traffic management and edge insight vision.
In the meantime, I will try to build based on the same Ubuntu version and see if the issue persists.
