Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Issue with Ia_visualizer
Jacky_Gupta
Hi
I have downloaded EIS_2.3.2 successfully. But when i run PCB demo i get issue related to tkinter, due to which visualizer fails.
Everything was working for me in EIS_2.2.1 and EIS_2.3.1.
I have also run "xhost +" command  several times. Pasted failure snippets below.
Also attached snapshot of Successfully download of EIS_2.3.2 ,creation of all the containers, and logs of entire container.
ia_tls_remoteagent | Traceback (most recent call last):
ia_tls_remoteagent | File "tls_remote_agent.py", line 626, in <module>
ia_tls_remoteagent | main()
ia_tls_remoteagent | File "tls_remote_agent.py", line 545, in main
ia_tls_remoteagent | window = Tk()
ia_tls_remoteagent | File "/usr/lib/python3.6/tkinter/__init__.py", line 2023, in __init__
ia_tls_remoteagent | self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
ia_tls_remoteagent | _tkinter.TclError: couldn't connect to display ":0"
ia_visualizer exited with code 1
Murni_J_Intel
Hi @Jacky_Gupta
Based on the screenshot of the log that has been attached, I assume that this machine already connected to the display.  Few things that you can try as below.
1. Reboot the machine and run xhost + command again.
2. Reboot the machine, go to the [EII_WORK_DIR]/build, issue $ docker-compose down command. After all the container is being stopped, run the $ xhost + command and run $ docker-compose up -d to bring up the container again.
let me know if the issue is still persist.
Jacky_Gupta
Hi @Murni_J_Intel ,
Thanks for your reply.But i had already rebooted the machine ran provisioning,rebuild the entire EIS using
"./provision_eis.sh ../docker-compose.yml
docker-compose up --build -d".
Did "$ docker-compose down/up."
Even reinstalled entire four times before posting this issue.In all this several attempts i was facing the same issue.
Jia-Shing_W_Intel
If you do "echo $DISPLAY", what do you get? If it's different from ":0", try to change the DISPLAY environmental variable in the docker-compose.yml file, and this should fix your problem.
ia_visualizer:
[removed]...
   environment:
      AppName: "Visualizer"
      DISPLAY: ${DISPLAY}
