Hi Intel team,
I used the Metro AI Suite Device Qualification Tool for testing. When I ran the esdq run command, it finished very quickly and didn’t seem to actually perform any tests. It was only when I executed run.sh that the tests appeared to be running. After the tests finished, running esdq run again would then generate a report.
esdq version is 11.1.0
All modules are already installed.
Hi JanHung,
I can generate the report when running the esdq run command:
This could be a glitch from the package or the machine.
Zul
Hi JanHung,
Zul
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
