Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Metro AI Suite Device Qualification Error
JanHung
Hi Intel team,
I found an issue in the draw_graph function of AI_box_runtimeDL.py. It seems that dgpu_df does not contain the "gpu_util" field, which causes the GPU Frequency Performance Test to fail.
However, when I commented out the relevant code, as shown in the screenshot below, the GPU Frequency Performance Test passed.
GPU:Intel® Arc™ A730M Graphics
Zulkifli_Intel
Hi JanHung,
Greetings to you.
Thank you for sharing your findings with us.
I wasn't able to reproduce the issue. When running the Run AI Frequency Measurement command:
esdq --verbose module run metro-device-qualification --arg "-r FreqRunner -t 1"
I didn't observe any error. Can you share the GPU performance result?
Zul
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
