Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
[Metro AI Suite Device Qualification] Failed on Media Performance Test & LPR Proxy Pipeline
chiao
Hi Intel Support Team,
We ran Metro AI Suite Device Qualification (V2.0) on our platform and observed two failed test cases:
  • Media Performance Test – FAILED
  • License Plate Recognition (LPR) AI Proxy Pipeline Benchmark – FAILED
Attachments we will provide:
  1. TwoFailed report.zip
  2. Media Performance Test_Failed.txt
  3. LPR AI Proxy Pipeline Benchmark_Failed.txt
Could you please advise how to resolve the failure?
Thank you for your support.
Denise
wilford139
Hi Denise,
For the Media Performance Test failure, make sure your drivers and firmware are up to date and that hardware acceleration is enabled. For the LPR AI Proxy Pipeline Benchmark, ensure all AI runtime dependencies are installed and memory allocations meet the benchmark requirements. After updating these, re-run the tests.
JesusE_Intel
Hi Denise,
Based on the report, it appears that some software components were not installed properly. Did you encounter any errors during the installation process? The following components appear to be missing, which is preventing the tests from running. Could you try running the installation script once more and share the contents of /var/log/esb-cli/Metro_AI_Suite_Device_Qualification_for_Hardware_Builder_2.0/?
Intel Level Zero for GPU
Libva / VAAPI Driver
Mesa
Jesus
chiao
Hi Jesus,
I didn't encounter any errors during the installation process. I have reruned the installation script, please refer to the attached Metro_AI_Suite_Device_Qualification_for_Hardware_Builder_2.0.zip
Denise
wilford139
Hi Denise,
JesusE_Intel
Hi Denise,
Thanks for providing the logs, I'm not seeing any issues there. Was this a fresh Ubuntu 24.04 installation? Can you please try to install the GPU drivers using the following documentation?
https://dgpu-docs.intel.com/driver/client/overview.html
Once that is done, try to run the tests again.
Jesus
JesusE_Intel
If additional assistance is needed, please start a new discussion as this one will no longer be monitored.
