Edge Software Catalog
474 Discussions
Module validation failed on ESDQ AIBOX 2.5/2.0 AMR 2022.3.1/2022.3.0 Vision
huang__shiuan-chi
We tried to run ESDQ package install,
During installing,
there will be Module validation failed error on
Docker_Community_Edition_CE and Azure_IoT_PnP_Bridge Module
This will happen on all ESDQ that include these test Module, and cause install failed.
JesusE_Intel
I just retested the installation using Intel® Edge Software Device Qualification (Intel® ESDQ) for EI for AMR version 2022.3.1 and didn't run into any issues. Could you please try to install the software package once more and let me know if it works for you as well?
Successfully installed amr-kudan-slam took 2 minutes 19.73 seconds
Installation of package complete
***Recommended to reboot system after installation***
|            Id            |            Module           |  Status |
| 62f3aa229d0187002145ddf6 |      amr-wwan-5g-modem      | SUCCESS |
| 62f3bc5b9d0187002145de12 |       amr-collab-slam       | SUCCESS |
| 62f3ba929d0187002145de11 |       amr-slam-toolbox      | SUCCESS |
| 62f3b8ec9d0187002145de10 |    eiforamr-openvino-sdk    | SUCCESS |
| 62f3b8b19d0187002145de0f |        amr-turtlebot3       | SUCCESS |
| 62f3b8789d0187002145de0e |         amr-adbscan         | SUCCESS |
| 62f3b81d9d0187002145de0c |      eiforamr-base-sdk      | SUCCESS |
| 62f3b7dd9d0187002145de0b |          amr-kobuki         | SUCCESS |
| 62f3b7ae9d0187002145de0a |      amr-battery-bridge     | SUCCESS |
| 62f3b7769d0187002145de09 |        amr-imu-tools        | SUCCESS |
| 62f3b7419d0187002145de08 |           amr-nav2          | SUCCESS |
| 62f3b6ee9d0187002145de07 |  eiforamr-full-flavour-sdk  | SUCCESS |
| 62f3b6ad9d0187002145de06 |      amr-vda-navigator      | SUCCESS |
| 62f3b5989d0187002145de05 |         amr-rtabmap         | SUCCESS |
| 62f3b5429d0187002145de04 |     amr-fleet-management    | SUCCESS |
| 62f3b2eb9d0187002145ddfe |     amr-collab-slam-gpu     | SUCCESS |
| 62f3b40c9d0187002145de03 |          amr-gazebo         | SUCCESS |
| 62f3b3d79d0187002145de02 |         amr-rplidar         | SUCCESS |
| 62f3b39e9d0187002145de01 |       amr-fastmapping       | SUCCESS |
| 62f3b3529d0187002145de00 |       amr-ros1-bridge       | SUCCESS |
| 62f3b31a9d0187002145ddff |        amr-wandering        | SUCCESS |
| 62f3b23d9d0187002145ddfd |     amr-object-detection    | SUCCESS |
| 62f3af9d9d0187002145ddfc |      amr-ros2-openvino      | SUCCESS |
| 62f3aef79d0187002145ddfb |   amr-vda5050-ros2-bridge   | SUCCESS |
| 62f3aebb9d0187002145ddfa |        amr-realsense        | SUCCESS |
| 62f3ae7d9d0187002145ddf9 |       amr-cartographer      | SUCCESS |
| 62f3ae3b9d0187002145ddf8 |   amr-aaeon-amr-interface   | SUCCESS |
| 62f3adcd9d0187002145ddf7 |    amr-robot-localization   | SUCCESS |
| 62f3a69b9d0187002145ddf4 |       amr-ros-arduino       | SUCCESS |
| 62f3a6cd9d0187002145ddf5 |      amr-sick-nanoscan      | SUCCESS |
| 62f3a6709d0187002145ddf3 |        amr-gstreamer        | SUCCESS |
| 62f3a49a9d0187002145ddf2 |        amr-turtlesim        | SUCCESS |
| 62f3a4209d0187002145ddf1 |        amr-fdo-client       | SUCCESS |
| 62f3a1779d0187002145ddef |         amr-ros-base        | SUCCESS |
| 62f3c2590f5af50020aa44d2 |             esdq            | SUCCESS |
| 605cab935a4b53002c272678 | Docker Community Edition CE | SUCCESS |
| 60e58fca4c1e9d002a6d6b2a |        Docker Compose       | SUCCESS |
| 639c7e6e5906997fb51b9491 |        amr-kudan-slam       | SUCCESS |
pse@esh-ubuntu20:~/Downloads/edge_insights_for_amr$ cat edgesoftware_configuration.xml
<?xml version="1.0"?>
<manifest>
  <main label="Edge_Insights_for_Autonomous_Mobile_Robots" version="2022.3.1" id="63bd9883f5f459460445aea6" packageId="20a34140-22e1-40e0-ba89-8d92616476b3" osId="60126c55d9555f002a8                       049fb"/>
  <default path="installation/common" esb_install="true" label="esb_common" id="6022bd8ccc7449002afdbedd"/>
  <project path="installation/src" id="62f4b6f54d3c980023d2314a" version="2022.3" label="AMR_containers"/>
  <project path="installation/src" id="62fb5e844d3c980023d23265" version="2022.3" label="AMR_containers"/>
  <image id="62f3aa229d0187002145ddf6" label="amr-wwan-5g-modem" tag="2022.3"/>
  <image id="62f3bc5b9d0187002145de12" label="amr-collab-slam" tag="2022.3"/>
  <image id="62f3ba929d0187002145de11" label="amr-slam-toolbox" tag="2022.3"/>
  <image id="62f3b8ec9d0187002145de10" label="eiforamr-openvino-sdk" tag="2022.3"/>
  <image id="62f3b8b19d0187002145de0f" label="amr-turtlebot3" tag="2022.3"/>
  <image id="62f3b8789d0187002145de0e" label="amr-adbscan" tag="2022.3"/>
  <image id="62f3b81d9d0187002145de0c" label="eiforamr-base-sdk" tag="2022.3"/>
  <image id="62f3b7dd9d0187002145de0b" label="amr-kobuki" tag="2022.3"/>
  <image id="62f3b7ae9d0187002145de0a" label="amr-battery-bridge" tag="2022.3"/>
  <image id="62f3b7769d0187002145de09" label="amr-imu-tools" tag="2022.3"/>
  <image id="62f3b7419d0187002145de08" label="amr-nav2" tag="2022.3"/>
  <image id="62f3b6ee9d0187002145de07" label="eiforamr-full-flavour-sdk" tag="2022.3"/>
  <image id="62f3b6ad9d0187002145de06" label="amr-vda-navigator" tag="2022.3"/>
  <image id="62f3b5989d0187002145de05" label="amr-rtabmap" tag="2022.3"/>
  <image id="62f3b5429d0187002145de04" label="amr-fleet-management" tag="2022.3"/>
  <image id="62f3b2eb9d0187002145ddfe" label="amr-collab-slam-gpu" tag="2022.3"/>
  <image id="62f3b40c9d0187002145de03" label="amr-gazebo" tag="2022.3"/>
  <image id="62f3b3d79d0187002145de02" label="amr-rplidar" tag="2022.3"/>
  <image id="62f3b39e9d0187002145de01" label="amr-fastmapping" tag="2022.3"/>
  <image id="62f3b3529d0187002145de00" label="amr-ros1-bridge" tag="2022.3"/>
  <image id="62f3b31a9d0187002145ddff" label="amr-wandering" tag="2022.3"/>
  <image id="62f3b23d9d0187002145ddfd" label="amr-object-detection" tag="2022.3"/>
  <image id="62f3af9d9d0187002145ddfc" label="amr-ros2-openvino" tag="2022.3"/>
  <image id="62f3aef79d0187002145ddfb" label="amr-vda5050-ros2-bridge" tag="2022.3"/>
  <image id="62f3aebb9d0187002145ddfa" label="amr-realsense" tag="2022.3"/>
  <image id="62f3ae7d9d0187002145ddf9" label="amr-cartographer" tag="2022.3"/>
  <image id="62f3ae3b9d0187002145ddf8" label="amr-aaeon-amr-interface" tag="2022.3"/>
  <image id="62f3adcd9d0187002145ddf7" label="amr-robot-localization" tag="2022.3"/>
  <image id="62f3a69b9d0187002145ddf4" label="amr-ros-arduino" tag="2022.3"/>
  <image id="62f3a6cd9d0187002145ddf5" label="amr-sick-nanoscan" tag="2022.3"/>
  <image id="62f3a6709d0187002145ddf3" label="amr-gstreamer" tag="2022.3"/>
  <image id="62f3a49a9d0187002145ddf2" label="amr-turtlesim" tag="2022.3"/>
  <image id="62f3a4209d0187002145ddf1" label="amr-fdo-client" tag="2022.3"/>
  <image id="62f3a1779d0187002145ddef" label="amr-ros-base" tag="2022.3"/>
  <project path="installation/src" id="62f60d914d3c980023d23218" version="2022.3" label="Source_Code_Distribution_under_GPL"/>
  <project path="installation/src" id="62f3c2590f5af50020aa44d2" version="9.0" label="esdq" esb_install="true"/>
  <project path="installation/src" id="631733c35193e50021cb2080" version="2022.3" label="esdq/AMR_Test_Module"/>
  <project path="installation/src" id="631865d45193e50021cb21b5" version="2022.3" label="AMR_containers"/>
  <project path="installation/src" id="605cab935a4b53002c272678" version="20.10.5" label="Docker_Community_Edition_CE" esb_install="true"/>
  <project path="installation/src" id="60e58fca4c1e9d002a6d6b2a" version="1.29.0" label="Docker_Compose" esb_install="true"/>
  <image id="639c7e6e5906997fb51b9491" label="amr-kudan-slam" tag="2022.3.1"/>
If you run into any docker pull issues, please configure non-root user permissions as mentioned here:
Linux post-installation steps for Docker Engine | Docker Documentation
Jesus
JesusE_Intel
Hi huang__shiuan-chi,
Thank you for reporting, I believe this is the same issue reported in this discussion thread:
https://community.intel.com/t5/Intel-Edge-Software-Hub/Install-ESDQ-for-AI-Box-for-Video-Analytics-has-fail-item/m-p/1465448#M1656
I have escalated this issue to the development team. Let me follow up with them and share an update soon.
Jesus
henry1758f
Is there any update about this?
Will the ESDQ project keep updating and going?`
JesusE_Intel
<manifest>
Jesus
JesusE_Intel
