Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
No access "http://localhost:5000"
HuynhVanThuan
I have successfully run EII but for some reason I still can't access "http://localhost:5000" even though I followed the instructions. Can anyone help me? Here are all the files I followed your instructions
cindyl
Hi Huynh,
It seems like that there's an issue with the UDF. You can either create a new UDF or edit the current UDF for classification. If you are unsure about the code, you can refer to the file from "/Edge_Insights_for_Industrial_2.6.2/training-and-learning-suite/nnframework/tf/inferOpenvino/classificationInfer.py".
Cindy
Sahira_Intel
It looks like the app was successfully launched but I would like to try to replicate this error.
Can you please share more information about this error. Are you trying to run an EII demo?
Sincerely,
Sahira
HuynhVanThuan
Hi Sahira,
I want to give you a few more photos in this post. Hope it will give you a lot of useful information. If you need any information please let me know. Thank you so much
Mr. Huynh Van Thuan
cindyl
Hi Huynh,
Can you share the logs for ia_video_analytics and ia_video_ingestion?
 $ docker logs -f ia_video_analytics
 $ docker logs -f ia_video_ingestion
Cindy
HuynhVanThuan
Hi Cindy,
The document you need to see is here. If you need any more information, please let me know. I am very happy about this. Thank you so much
Mr. Huynh Van Thuan
cindyl
Hi Huynh,
Seems like there is an error with the custom UDF. May I know whether you are doing classification or object detection?
Cindy
HuynhVanThuan
Hi Cindy,
I'm doing object classification. If you need any more information let me know. Thanks
Huynh
cindyl
Hi Huynh,
Cindy
HuynhVanThuan
Hi Sahira,
I want to make a demo application as mentioned from slide 35 -> 37 (AI4I Day 5 & 6.pdf) and I need to be able to access the "http://local:5000" link to be able to do this.
Here is the sequence I did while running EII
1. copy ais to /home/ais/edge_insights_industrial/Edge_Insights_for_Industrial_2.6/IEdgeInsights/common/video/udfs/python
2. copy and replace .xml and bin files to /home/ais/edge_insights_industrial/Edge_Insights_for_Industrial_2.6/IEdgeInsights/common/video/udfs/python/ais/ref
3. Add label in labels.txt in /home/ais/edge_insights_industrial/Edge_Insights_for_Industrial_2.6/IEdgeInsights/common/video/udfs/python/ais/ref
4. go to /home/ais/edge_insights_industrial/Edge_Insights_for_Industrial_2.6/IEdgeInsights/build and run the builder script for video-streaming use case
python3 builder.py -f usecases/video-streaming.yml
5. Replace config files:
a. copy and replace classification/eii_config.json in /home/ais/edge_insights_industrial/Edge_Insights_for_Industrial_2.6/IEdgeInsights/build/provision/config if doing classification
b. copy and replace object detection/eii_config.json in /home/ais/edge_insights_industrial/Edge_Insights_for_Industrial_2.6/IEdgeInsights/build/provision/config if doing object detection
6. provision, build and run
cd provision && sudo -E ./provision.sh ../docker-compose.yml
cd .. && docker-compose -f docker-compose-build.yml build
docker-compose up -d
7. to clode EII visualizer, run the following command in the same terminal
docker-compose down
After I completed the above command sequence successfully, I continued to follow the command sequence in the file "AI41_node_red_command.txt" to be able to access the address "http://localhost:5000". Besides, I also refer to the document "AI4I Day 5 & 6.pdf" from slides 10 -> 12 and 16 -> 18 to execute the following sequence of commands
1. Install Visual Studio code
sudo snap install --classic code
2. Preparing your MQTT Broker
sudo nano /etc/mosquitto/mosquitto.conf
bind_address 0.0.0.0
port 1884
sudo systemctl restart mosquitto.service
sudo systemctl status mosquitto.service
3. Include MQTT in the docker for Video analytics
numpy==1.18.0
paho-mqtt==1.4.0
4. Include mqtt in the udf
import paho.mqtt.client as mqtt
client = mqtt.Client()
client.connect("192.168.100.21", 1884, 60)
client.publish("/ais/",json.dumps({"Result":defects}))
5. Modify UDF: Provision, build and run
After done come here. I started accessing "http://localhost:5000" and I still can't access it even though I don't know where I went wrong
