Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Service 'oneapi' failed to build (EI for AMR)
a123a20
Version: Edge Insights for Autonomous Mobile Robots 2021.4
OS version: Ubuntu 20.04.3 LTS
I try to install Edge Insights for Autonomous Mobile Robots,  I follow and execute commands in content.
But I got error messages 'ERROR: Service 'oneapi' failed to build ' during the Step6: Build the Docker* images after executing the following command:
docker-compose -f 01_docker_sdk_env/docker_compose/01_amr/amr-sdk.all.yml build --parallel --no-cache
or
How can I resolve it?
JesusE_Intel
Hi a123a20,
I just installed Edge Insights for AMR following the documentation and I didn't see this error. Could you try re-running the docker-compose without --no-cache one more time?
../docker_entrypoint.sh        0.0s
 => exporting to image        0.0s
Building oneapi      ... done
 => => writing image sha256:a0da8c4086338834216068ef35ffaecad82b0404c035d9177e50a1e92c068fa0                                                     0.0s
 => => naming to docker.io/library/amr-ubuntu2004-ros2-foxy-oneapi:2021.4                                                               0.0s
Successfully built a0da8c4086338834216068ef35ffaecad82b0404c035d9177e50a1e92c068fa0
If you still see an error it may be an issue with the Intel® oneAPI Base Toolkit version in this release. Please make the following changes and you should be able to have a successful built.
Edit the 01_amr/dockerfile.stage.oneapi file:
         # Change line 41 from:
         intel-oneapi-dpcpp-ct=2021.4.*
         # To:
         intel-oneapi-dpcpp-ct=2022.0.0*
         # Change lines 48-53 from:
         intel-igc-opencl=1.0.8365
         intel-igc-core=1.0.8365
         intel-opencl=21.33.20678
         intel-level-zero-gpu=1.1.20678
         level-zero=1.4.1
         level-zero-devel=1.4.1
         # To:
         intel-igc-opencl=1.0.8517
         intel-igc-core=1.0.8517
         intel-opencl=21.37.20939
         intel-level-zero-gpu=1.2.20939
         level-zero=1.6.2
         level-zero-devel=1.6.2
And edit the 01_docker_sdk_env/dockerfile.amr file:
         # Change line 224 from:
         FROM intel/oneapi-basekit:2021.4-devel-ubuntu18.04 AS oneapi_base
         # To:
         FROM intel/oneapi-basekit:2022.1.1-devel-ubuntu18.04 AS oneapi_base
Jesus
JesusE_Intel
Hi a123a20,
         # To:
         level-zero=1.4.1
         # To:
         level-zero=1.6.2
         # To:
Jesus
a123a20
Today build success.
Thanks for your information.
Isaac
