Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Realsense D435 Issue
DarkHorse
My customer has been seeing these issue with the following hardware settings:
  1. IPC model: Vecow Industrial PC SPC-5600A (Core i7)  https://www.vecow.com/dispUploadBox/PJ-VECOW/Files/5048.pdf
  2. Camera model: Intel Realsense D435
  3. USB model: 3.1 A-C Dual Screw Black Newnex Black 5m 2.0 #U3S1A01C12-050 https://www.newnex.com/usb-type-c-cables-legacy.php
  4. AMR1: 1x D435 connected to IPC USB port type: 2.0; 1x D435 connected to IPC USB port type: 3.2
  5. AMR2: 2x D435 connected to IPC USB port type: 3.2
Ubuntu 18.04.5
Kernel 4.15.0-112-generic
RealSense ROS v2.3.2
LibRealSense v2.50.0
Device FW version: 05.13.00.50
The issues that they are seeing are:
  1. 100% hang if loading the DefaultPreset_D435.json file.
  2. Occasionally (less than 10%) not able to get data from D435 after a stop-start.
  3. Occasionally Ubuntu OS freeze (less than 10%) after a stop-start.
  4. Occasionally hang when start camera node in ROS function.
Please advise on this .
Sahira_Intel
Can you you/your customer please open a thread in the RealSense community and we can certainly help them there.
Sincerely,
Sahira
