Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Timeout issue on webvisualizer UI
Snehal_Yesugade
We have CSL network with server - node1 - node2
Whenever we tried to increase number of ingestions, we could observer that connection to webvisualizer based UI gives timeout (while connecting with virtual IP:31505)
We could see below message for wget
"HTTP request sent, awaiting response....read error(connection reset by peer) in headers.
Retrying"
WengWai_C_Intel
@Snehal_Yesugade
As WebVisualizer is being setup as secured connection using https, you should run the wget command with https instead of http. Below is an example:
wget <https://CSL_virtual_IP:31505> --no-check-certificate
WengWai_C_Intel
@Snehal_Yesugade
JesusE_Intel
