Edge Software Catalog
add veb/vepa
migo_gong
Hello,I want to add veb/vepa and vsi through commands on the pv of xl710.But i am having some problems adding veb and vsi.
I can correctly add floating VEBs. But an error occurred while adding VEB with uplink and downlink.Appear “AQ command send failed Opcode 230 AQ Error:14    AQ desc WB 0x0007 0x0230 0x0000 0x000e 0x00000000 0x00000000 0x01860002 0x00ff0003 0x00000000 0x000b0000”
Secondly I also got error while adding vsi.
I put more detailed information in the attachment.
JesusE_Intel
JesusE_Intel
Hi migo_gong,
Thanks for reaching out! Could you please share more information about your setup and which software package from Edge Software Hub are you using?
Jesus
JesusE_Intel
