Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
deployment get fail
WeiSeng
I try on Smart Edge Open.
When i run: $pipenv run ./deploy.pypipenv run ./deploy.py
Error:
fatal: [node01]: FAILED! => {
"assertion": "ansible_nodename is match('^([a-z0-9]+(\\.|-)?)+[a-z0-9]+$')",
"changed": false,
"evaluated_to": false
MSG:
Assertion failed
fatal: [node02]: FAILED! => {
"changed": false,
MSG:
Assertion failed
fatal: [node03]: FAILED! => {
"changed": false,
MSG:
Assertion failed
fatal: [controller]: FAILED! => {
"changed": false,
MSG:
Assertion failed
Any suggestion?
JesusE_Intel
Hi WeiSeng,
Could you share more information about your setup? Did you update the yml file as mentioned in the Get Started Guide: Set up the Intel® SecL - DC Controller Node, Intel® SGX Provisioning Certificate Caching Service (PCCS), and KMRA app-hsm(Key server) Service?
Jesus
JesusE_Intel
Hi WeiSeng,
Jesus
WeiSeng
thanks resolved
JesusE_Intel
