Edge Software Catalog
478 Discussions
eci - run sudo apt install libudev-dev not depends :libudev-dev not install
junjuns
install libudev-dev depends : error libudev-dev :Depends :libudev1 (=249.11-0ubuntu3.12) but 249.11-0ubuntu3.12-ecir5.......,
Iffa_Intel
to clarify, could you share:
  1. your OS and version (eg: Ubuntu 22.04)
  2. your hardware info (eg: CPU GPU etc)
  3. your reference eg url of the ECI guide (to clarify whether you are referring to the latest guide)
Cordially,
Iffa
junjuns
apt dependency problem, is a different package from eci, installed libudev-dev 249.11-0ubuntu3.12-ecir5........ deb, you have found the eci compilation directory, put the dpkg-i package name.deb on the target machine, and install it.
Iffa_Intel
could you elaborate further regarding your issue?
Do you mean that you are unable to install libudev-dev using the command sudo apt install libudev-dev after installing the ECI package?
Please help to provide informations that I asked previously too.
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread
Cordially,
Iffa
