Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
iGPU in IoTEdge EFLOW Docker
davidrc
I am trying to dockerize an application that requires GPU Acceleration (At least OpenCL) and deploy it to Azure IoTEdge, however I am not able to view any result inside the docker container using the clinfo command while running the container inside IoTEdge's EFLOW. I have done the steps indicated in the following articles, however still I am not able to use view the gpu inside a docker container.
https://docs.microsoft.com/en-us/azure/iot-edge/gpu-acceleration?view=iotedge-2020-11
https://docs.microsoft.com/en-us/azure/iot-edge/gpu-acceleration?view=iotedge-2020-11#using-gpu-acceleration-for-your-linux-on-windows-deployment
https://www.intel.com/content/www/us/en/developer/articles/technical/deploy-reference-implementation-to-azure-iot-eflow.html#learn-more
For reference, I have been able to successfully view the GPU inside a docker container running on a WSL environment installing the correct drivers and using the following command:
docker run -it --device /dev/dxg --volume /usr/lib/wsl:/usr/lib/wsl <image_name>
However I couldn't replicate that inside EFLOW because there is no /dev/dxg device
Any thoughts on how could I access the iGPU inside a docker in EFLOW, or at least how to verify if I have done the steps shown in the links correctly?
Xiang_Intel
Hi Davidrc,
Sorry for the late catch-up. Just to check with you again, do you enable ParaVirtualization for GPU when you are running your Deploy-Eflow command? Without specifying this you will not able to see /dev/dxg device in your EflowVM.
Here is the sample of the command that you can use:
$cpu_count = 4
$memory = 4096
$hard_disk = 30
$gpu_name = (Get-WmiObject win32_VideoController | where{$_.name -like "Intel(R)*"}).caption
Deploy-Eflow -acceptEula yes -acceptOptionalTelemetry no -headless -cpuCount $cpu_count -memoryInMB $memory -vmDiskSize $hard_disk -gpuName $gpu_name -gpuPassthroughType ParaVirtualization -gpuCount 1
You should be able to see /dev/dxg device if GPU is passthrough correctly to the EflowVM
Lim Xiang Yang
Xiang_Intel
Hi Davidrc,
May I know if I can get more info?
  1. Windows Version that is used?
  2. Intel graphics driver that is installed?
  3. System processor that is used?
Lim Xiang Yang
davidrc
Sure,
  1. Windows 10 Pro version 21H2
  2. Intel® Graphics – Windows DCH Drivers version 30.0.101.1660 and (inside docker) Intel Compute Runtime + OpenCL Driver version 22.15.22905
  3. Intel Core i7-8560U With UHD Graphics 620
Xiang_Intel
Hi Davidrc,
$cpu_count = 4
$memory = 4096
$hard_disk = 30
Lim Xiang Yang
JesusE_Intel
