Edge Software Catalog
472 Discussions
uwc - what all function codes are supported for Modbus in UWC ?
anujSoftdel
Which all FC's are supported in UWC.
Softdel4UWC
The Softdel-based stack used in the Intel UWC supports below below Function Codes -
  • 01 coil
  • 02 discrete input
  • 03 holding register
  • 04 input register
  • 05 write single coil
  • 06 write single register
  • 10 write multiple register
The stack supports multiple queues for message prioritization.
Please refer to Modbus guide for details about protocol - https://modbus.org/docs/PI_MBUS_300.pdf
dasamara
The UWC middleware reference contains Modbus RTU and Modbus TCP services for exchanging data from/to sensors' and actuators' coils, holding registers, etc.
Thank you for the question.   Someone will respond with a complete answer.  if you are interested to investigate further yourself, a user guide is available after downloading the UWC package.  https://software.intel.com/iot/edgesoftwarehub/download/home/ri/universal_wellpad_controller
Dean
Softdel4UWC
  • 01 coil
  • 02 discrete input
  • 04 input register
