Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
where is the orchestrator located ?
AlexandruUngureanu
I have tried to install the edge for instrustrial software on a intel network. I had to use the proxy for the installer to detect the presence of internet.
before (no proxy):
Checking Internet connection
Reconnecting
Check for Internet connection request timed out
Reconnecting
Please check the Internet connection and proxy settings
after (with proxy):
Connected to the Internet
This was not the single problem. The docker and docker-compose tools cannot be downloaded because of a blocked port. see logs:
Modules to be installed by package are ['Docker_Community_Edition_CE', 'Docker_Compose', 'eii_installer']
Installing Docker_Community_Edition_CE
Installing Docker [..................................................] 100%
13
Permission denied
Failed to install Docker_Community_Edition_CE took 36.54 seconds
Installing Docker_Compose
Verifying Docker [..................................................] 100%
Installing Docker Compose [......................................... ] 83%
Failed to download docker-compose % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- 0:02:10 --:--:-- 0curl: (7) Failed to connect to github.com port 443: Connection timed out
Failed to install Docker_Compose took 2 minutes 21.50 seconds
Installing eii_installer
Verifying Docker Compose [......................... ] 50%
sudo: docker-compose: command not found
Failed to verify docker_compose_verify
Failed to install eii_installer took 10.88 seconds
Installation of package complete
As a side note, for this you could use the http or https to download the binaries from github, no need for a separate port 443.
Finally the installer result was like:
| Id | Module | Status |
| 5f21392e9e63c9002a6fd88d | Docker Community Edition CE | SUCCESS |
| 5f213aae9e63c9002a6fd88e | Docker Compose | FAILED |
| 5face41098a1ef002af292fd | eii installer | FAILED |
Now, the question: Where should the orchestrator component be located ? I've searched for "orchestrator" in the installer directory and did not found it. Do you think this could be because the installer was not complete ? I need to investigate the orchestration solution for this components.
I've also tried to install docker-compose separately before but after installer execution, the binary it's not there anymore (/usr/local/bin/docker-compose) and maybe the installer deleted it.
Full logs attached.
AlexU
Jia-Shing_W_Intel
The installer for the recommended configuration no longer comes with orchestrator by default. You can verify this by looking for "orchestrator" in the edgesoftware_configuration.xml file.
To include it, you need to create a customized installation package by clicking the "Customize & Download" button at https://software.intel.com/iot/edgesoftwarehub/download/home/industrialinsights/. At step 2, you can add Orchestrator to your package.
About the installation of docker and docker-compose, curl is used to download the official Docker GPG key and the docker-compose binaries via https, and thus a proxy setting is required if you are behind a proxy server.
Jia-Shing_W_Intel
mbulgaru
What worked for me so far was commenting the last line from:
/etc/apt/sources.list
# deb-src [arch=amd64] https://download.docker.com/linux/ubuntu bionic stable
Deleted the bolded S from this file:
/etc/apt/apt.conf.d/proxy.conf
Acquire::https::proxy "https://proxy-chain.intel.com:912";
But first verify if both files below look like this:
cat /etc/systemd/system/docker.service.d/http-proxy.conf
[Service]
Environment="HTTP_PROXY=http://proxy-chain.intel.com:911"
Environment="HTTPS_PROXY=http://proxy-chain.intel.com:912"
Environment="NO_PROXY=intel.com,.intel.com,localhost,127.0.0.1"
cat ~/.docker/config.json
"proxies":
"default":
"httpProxy": "http://proxy-chain.intel.com:911",
"httpsProxy": "http://proxy-chain.intel.com:912"
Maria-Luiza
Murni_J_Intel
Hi @mbulgaru
for /etc/systemd/system/docker.service.d/http-proxy.conf file I would suggest the NO_proxy as below
Environment="NO_PROXY=*.intel.com,localhost,127.0.0.1"
after done you will need to restart the docker to flush the changes.
sudo systemctl daemon-reload
$ sudo systemctl restart docker
You can verify the configuration has been loaded based on the changes you made using the below command
$ sudo systemctl show --property=Environment docker
