Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
941 Discussions
Bootutils reports unknown Flash for i210 - Trying to add PXE boot support
PJK
Trying to add PXE boot support for Intel i210 Gigabit Ethernet PHY, but bootutils does not recognize the flash. The tools lanconf64 and eeupdate work well. The Flash is programmed and the PHY operates normally, but it is not possible to configure PXE boot due to the fact that bootutils does not recognize the flash.
Please advise or suggest another way of enabling PXE boot.
Part number: WGI210IT_S_LJXT
Flash type: Winbond W25Q16JVSNIQ,
i210 image: Dev_Start_I210_Copper_NOMNG_16Mb_A2_3.25_0.03.bin
An example is added below using bootutils.efi, but the result is the same whether used in an OS or in the EFI shell.
Mike_Intel
Hello PJK,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Please wait for their reply within 1 to 2 business days.
Thank you and stay safe.
Michael L.
CarlosAM_INTEL
Hello, @PJK:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
samwu0727
hi~
where can i download the PXE ROM for I210 ?
thanks a lot~
CarlosAM_INTEL
Hello, @samwu0727:
We sent an email to the address related to this account with information that may help you.
@CarlosAM_INTEL.
Cathy_Chen
where can I download the PXE ROM for I210 ?
CarlosAM_INTEL
Hello, @Cathy_Chen:
The information that may help you is stated in the answer to question 2.19, on page 8 of the document stated in the following website:
https://cdrdv2-public.intel.com/334026/ethernet-controller-i210-i211-faq.pdf
@CarlosAM_INTEL.
Cathy_Chen
hi~
Hi~ I've been trying to create an EFI image using BootUtil, but I haven't achieved the desired results.
Is there a more detailed step-by-step guide available? I
specifically need EFI files related to I210.
CarlosAM_INTEL
Hello, @Cathy_Chen:
Thanks for your reply.
The information that may help you can be found in the document stated in the following website:
https://www.intel.com/content/dam/support/us/en/documents/network-and-i-o/ethernet-products/bootutil.txt
@CarlosAM_INTEL.
