Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
921 Discussions
How to get EepromAccessTool for I210 chipset?
rayn_81
I am developing custom board.
I am using "Ethernet Controller I210".  But ethernet interface is not working.
My environment is linux and kernel version is 4.18.
I already installed igb driver(5.14).
Here I have a question.
Does "Ethernet Controller I210" need programming?
Fariz_Intel
Hi rayn_81,
It seems that your question is related to design using Ethernet Controller I210. We might have a forum for those specific issues and we are moving it to Embedded Connectivity so it can get answered accordingly.
Fariz_Intel
Diego_INTEL
Hello @rayn_81,
The i210 supports flash-less operation, you can try with the document #348742 - Intel® Network Connections Tools 28.2 PV LAN Software Tools.
If you are using ARM, you can check the document #572162 - EEPROM Access Tool [EAT].
And the document #513655 - Intel® Ethernet Controller I210 and I211- AT Production NVM Images may be helpful.
You will need a Premier account in order to get access to these documents.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Also, you can check the Supported Operating Systems for Intel® Ethernet Controllers (LOM):
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
@Diego_INTEL
