Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
E810-XXVAM2
Greif
I AM trying to Deal with a tagged VLAN on a receive packet.
I am trying to control certain registers on the chip that will allow me to pass the receive packet with tag value without striping the tag.
Any help would be appreciated. I am new to this E810 chip.
I have changed some fields, but I am still not getting any received messages. The incoming packet is a tag packet and I need to pass this packet thru without any stripping of the tag.
I have set the Global Configuration (L2 Tag Control - GL_SWT_L2TAGCTRL[n]), Location 13.2.2.8.5 within the E810 document, to the following:
GL_SWT_L2TAGCTRL. ETHERTYPE
0x8100
GL_SWT_L2TAGCTRL.ISVLAN   1
1
PRT_L2TAGSEN.NON_LAST_TAG
0
GL_SWT_L2TAGCTRL.INNERUP
1
GL_SWT_L2TAGCTRL.OUTERUP
0
GL_SWT_L2TAGCTRL.LONG
0
GL_SWT_L2TAGCTRL.HAS_UP
1
GL_SWT_L2TAGCTRL.ISMPLS
0
GL_SWT_L2TAGCTRL.ISNSH
0
GL_SWT_L2TAGCTRL.LENGTH
2
GL_SWT_L2TAGTXIB.OFFSET
0
GL_SWT_L2TAGTXIB.LENGTH  3
01b
GL_SWT_L2TAGRXEB.OFFSET
0
GL_SWT_L2TAGRXEB.LENGTH   3
01b
GL_SWT_L2TAGDATA0, GL_SWT_L2TAGDATA1
All zeros
Per Port Configuration (Controlled by Set Port Parameters command)
PRT_L2TAGSEN.ENABLE and
GL_L2TAGSEN_m_n (m= 0..3, n= 0..1)
1
The E810 Datasheet section 7.12.3.3 states that the tag extraction rules are controlled by the following:
 VSI_TSR.STRIPTAG, VSI_TSR.SHOWTAG, and VSI_TSR.SHOWPRIONLY bit fields.
Within Table 7-290 Tag Extraction Example, the document talks about “SHOWIV and L2TSEL”:
We, have SHOWIV and L2TSEL set to a 1, 0 respectfully.  Which selects Inner VLAN on L2TAG1.
However, I believe this only pertains to different cases assuming the first tag is an STag and the second tag is a VLAN.
We don’t have a Stag only a typical 802.1 (8100) vlan tag.
If the VSI_TSR.STRIPTAG, VSI_TSR.SHOWTAG, and VSI_TSR.SHOWPRIONLY bit fields control the extraction rules how do you set this for “DO nothing” just leave the packet as is.
The setting is set as follows:
VSI_TSR Register
VSI_TSR.STRIPTAG = 0
SHOWTAG = 0
SHOWPRIONLY = 0
VSI_TAR Register    per document 13.2.2.12.5
ACCEPTTAGGED = 0
ACCEPTUNTAGGED = 0
prt_tdpul2tagsen Register   per document 13.2.2.26.1
Enable = 1
Not sure what Table 7-292 is really saying. We have eight incoming Ports attached to an external switch which delivers the packet and tag. I don't see how the GL_L2TAGSEN_0_0 comes into play.
Diego_INTEL
Hello @Greif,
You can try asking in the Ethernet Products Community as here is only for Embedded Products.
https://community.intel.com/t5/Ethernet-Products/bd-p/ethernet-products
But I have been investigating on my own in our resources and could be a driver issue with ice, but I'm not entirely sure, you may try updating the driver to the latest release just in case.
Also, you can check these links:
https://github.com/torvalds/linux/commit/fe911c89756671fc553d8d67836a65151e04c4d7
https://github.com/torvalds/linux/compare/master...mfijalko:linux:another61mbuf
https://github.com/mfijalko/linux/tree/another61mbuf
@Diego_INTEL
Greif
Hi Diego,
I made a change to the driver that was given to me to use. I added the line ctxt->info.inner_vlan_flags |= ICE_AQ_VSI_INNER_EMODE_NOTHING.
It solved the problem of NOT throwing away the incoming tags, but I have no idea as to why.
I started Searching thru the code that you suggested and did not show any results on using ICE_AQ_VSI_INNER_EMODE_NOTHING.
I would really like to know why this line made the difference, However the device driver that was given to me is a half breed of Intel's driver for the E810.
I think at this time frame I will close the issue, unless someone can shed light on ctxt->info.inner_vlan_flags.
