Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
956 Discussions
Cannot program an I211 controller
JDubo5
Hello there,
I'm having issues flashing the I211 controller with the eepromARMtool. I've double checked both the HW and SW settings of my design and everything appears correct. Whenever I tried to flash the board using the eepromARMtool I always get the same results at the end: "Flash wordsize reg val: 15 register ffffffff". Also the dump of the nvm content is always blank. So I've 3 questions for you:
1) Is it ok that "Memory Type Present" is shown as "INVM+FLASH" when I run the eepromARMtool utility with no arguments?
root@board:/opt/tool# ./eepromARMtool
Intel(R) Eeprom ARM Tool ARM OTP Programming Tool
Provided under the terms of a CNDA. Do Not Distribute.
Copyright(C) 2013 by Intel(R) Corporation
NIC BUS DEV FUN Silicon Memory Type Present
1 1 0 0 I211 INVM+FLASH
2) Is it ok to get "Flash wordsize reg val: 15 register ffffffff" when I attempt to flash the board? I'm using "./eepromARMtool -nic=1 -write -f=/opt/tool/hex_files/I211_Invm_NoAPM_v0.6.HEX" and "./eepromARMtool -nic=1 -f=/opt/tool/hex_files/I211_Invm_NoAPM_v0.6.HEX" commands
root@board:/opt/tool# ./eepromARMtool -nic=1 -write -f=/opt/tool/hex_files/I211_Invm_NoAPM_v0.6.HEX
Intel(R) Eeprom ARM Tool NVM/OTP Programming Tool
Copyright(C) 2013-2014 by Intel(R) Corporation
Version 0.6.7
3) Can you double check the output from lspci -vvv to verify if everything looks correct?
01:00.0 Ethernet controller: Intel Corporation Device 1532 (rev 03)
Subsystem: Intel Corporation Device 0000
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Interrupt: pin A routed to IRQ 130
Region 0: [virtual] Memory at 13000000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at 1000 [size=32]
Region 3: [virtual] Memory at 13020000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable- Count=5 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port # 0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <16us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via WAKE#
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 00-a0-c9-ff-ff-00-00-00
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
Steering table in TPH capability structure
Capabilities: [1c0 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Novo.
CarlosAM_INTEL
Hello, jsdmichaud1 :
In order to be on the same page, could you please tell us if your design fulfills the requirements stated as answers to the questions 2.24, 2.14, and 2.15, on pages 9 and 8 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions (FAQs) document # 335346?
Please let us know the information that should answer the previous question.
Waiting for your reply.
Carlos_A.
