Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
924 Discussions
Command line Capabilities and bugs in LANConf-Tool
we need a simple Test-Environment for an 10GbE Fiber Ethernet-Switch (Bandwidth / PacketLoss).
We thought about using two Intel X520-SR2 Cards in combination with the LANConf-Tool.
Configuring one Interface as an "Simple Responder" the other one for "TXRX" Test.
So we are able to do a loopback test from one Card over the Fiber-Backbone back to the second card.
We did some evaluation and it's working well.
But ...
LANConf-Tool has very limited capabilities for automation via command line.
And there seems to be a bug in LANConf-Tool.
If you passing the "Packets" Parameter to the "TX" command, the following output shows "0" values.
but while transmitting and pressing "s" for statistics shows the correct values.
And in the resulting dump file "stats.log", the values for Bandwidth (Max. Avg.) are missing.
Is there a possibility to enhance command line usage of LANConf-Tool, or is there a better solution for this scenario ?
We do not need compliance tests or something like that. Just simple Go/NoGo tests for Quality-Assurance after assembly.
Thanks in advance and Regards,
Dennis Rohwerder
Production Support
Lufthansa Technik AG, Hamburg Germany
CarlosAM_INTEL
Hello, AtomicOne:
It is important to let you know that the Ethernet Adapter (such the https://ark.intel.com/products/39774/Intel-Ethernet-Converged-Network-Adapter-X520-SR2 Intel® Ethernet Converged Network Adapter X520-SR2) consultations should be addressed through the https://communities.intel.com/community/wired Wired Ethernet Forum.
However, the information that may help you is stated on pages from 150 to 180 of the https://cdrd.intel.com/v1/dl/getContent/566469 Harrisonville Test Event Training document # 566469.
This document is classified as Intel confidential, which requires a CDNA between your company and Intel as well as a Privileged Resource & Design Center (RDC) account. It can be requested by filling out the form stated at the following website:
https://www-ssl.intel.com/content/www/us/en/forms/design/registration-privileged.html https://www-ssl.intel.com/content/www/us/en/forms/design/registration-privileged.html
We hope that this information may help you.
Carlos_A.
