Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
i210 uboot driver
JMont14
We will be working with the i210 at uboot level to load eeprom configuration files and test the device.
I was wondering if anyone used the i210 uboot driver coded in e1000.c. I was looking at the source and I don't see it being called anywhere.
Br,
JM
CarlosAM_INTEL
Hello, JMonteiroCSW:
The information that may help you is stated as a reference at the https://lists.denx.de/pipermail/u-boot/2014-August/185860.html [U-Boot] [PATCH 0/2] e1000: add i210 support and https://lists.denx.de/pipermail/u-boot/2014-August/187011.html [U-Boot] [U-Boot,2/2] e1000: add i210 support threads.
In case that you need more details or have more consultations related to U-boot or the topic of this forum please address them as a reference as well to the channels stated at the http://www.denx.de/wiki/U-Boot/Contacts Contacts < U-Boot < DENX and/or https://lists.denx.de/listinfo/u-boot Mailing List U-Boot .
We hope that this information may help you.
Carlos_A.
