Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
Controller I225-IT
mustafaakdag
hello
how can ı get the reference design files for Controller I225-IT   ı plan to use 3 pcs on the same board
and also the software tools to update the firmware
in past we used a lot i210
Diego_INTEL
Hello @mustafaakdag,
Here you can find all information regarding the I225:
https://www.intel.com/content/www/us/en/products/details/ethernet/gigabit-controllers/i225-controllers/docs.html
You may check for the following:
-Document #596659 - Intel® Ethernet Controller I225/ I226 Datasheet
-Document #618457 - Intel® Ethernet Controller I225/ I226 IEEE Tool User Guide
-Document #607353 - Intel® Ethernet Controller I225/ I226 Design Considerations
For the tools you may check:
-Document #615722 - Intel® Ethernet Controller I225/ I226 LAN Tools
You will need a Premier account to get access to the documents.
@Diego_INTEL
mustafaakdag
for that web site it always say it is out of service now,  and from the explanations ı see there is no REF design
how can ı get the premier account
mustafa
Diego_INTEL
