Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
LANConf tool on ARM
AYang18
We adopt I350-AM4 on ARM platform, how enter the IEEE test mode for apply IEEE SI compliance test.
There are seem no such LANConf like tool for ARM. Please give advice and guidance.
BR
Austin 0321
CarlosAM_INTEL
Hello, 456123:
Based on the information stated in section 3.1, on page 14 of the Intel(R) LANConf User Manual contained in the docs file of the https://cdrd.intel.com/v1/dl/getcontent/348742 Intel Network Connections Tools 23.0 PV LAN Software Tools document # 348742, attached you may find the document that may help you.
Please let us know if you have any question or information related to this.
Carlos_A.
Wesley
This tool seems like base on x86 , not ARM base.
Could you please provide Lanconf in ARM base?
CarlosAM_INTEL
Hello, @Wesley:
The Intel(R) I210, I211, and X550 EEPROM Access Tool [EAT] document # 572162 is the tool that may help you. It can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/572162.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
JustinWang
Hi All
We also need some tool to launch test mode on I210 like below
For 1G
Peak differential output voltage (Test Mode 1)
Transmitter Distortion(Test Mode 4)
MDI Return Loss(Test Mode 4)
MDI Common-Mode Output voltage(Test Mode 4)
But EAT did not provide the function.
We still need the LANConf for ARM64 platform .
CarlosAM_INTEL
Hello, @JustinWang:
We sent an email to the address related to this account with information that may help you.
@CarlosAM_INTEL.
JustinWang
Hi @CarlosAM_INTEL
Thanks for your update. We got your mail for information.
You means about LANCConf will no more any update.
Ob my case , we only check on another channel . Is that right?
CarlosAM_INTEL
Hello, @JustinWang:
Thanks for your reply.
Please follow the suggestion provided in our email to receive the answer to your requests.
@CarlosAM_INTEL
