Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
DPDK20.11.9 runs failed on intel atom cpu
lgl_hust
DPDK ver: 20.11.9
cpu type:   Intel(R) atom  Celeron(R) CPU J1900 @ 1.99GHz
log error:
_mm_loadu_si128 (__P=0x1013b9c56) at /usr/lib/gcc/x86_64-linux-gnu/7/include/emmintrin.h:703,
received signal SIGILL, Illegal instruction.
Is there some incorrect macro when compiling dpdk 19.11.6 ?
Or should i return to the lower version of dpdk?
lgl_hust
system info: ubuntu-18.04.6-desktop-amd64
cpu info:
processor : 3
vendor_id : GenuineIntel
cpu family : 6
model : 55
model name : Intel(R) Celeron(R) CPU J1900 @ 1.99GHz
stepping : 9
microcode : 0x90d
cpu MHz : 1333.435
cache size : 1024 KB
physical id : 0
siblings : 4
core id : 3
cpu cores : 4
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer rdrand lahf_lm 3dnowprefetch epb pti ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms dtherm ida arat md_clear
bugs : cpu_meltdown spectre_v1 spectre_v2 mds msbds_only mmio_unknown
bogomips : 4000.00
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
CarlosAM_INTEL
Hello, @lgl_hust:
You need to address this type of consultation as a reference to the channel stated on the following website:
https://bugs.dpdk.org/
@CarlosAM_INTEL.
