Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
Software and tools to be used for programming the Ethernet controller WGI210A
Naveen_C
Hello all,
I'm using WGI210A Ethernet controller, which is connected to Kontron CPU module through PCIe.
  • The JTAG connector is mapped to the pins JTAG_TMS, JTAG_CLK, and JTAG_TDI of the Ethernet controller.
  • The flash memory FM25V02A-G (Infineon) is connected to pins NVM_SK, NVM_CS_N, and NVM_SI of the Ethernet controller, which correspond to pins WP_N, CS_N, and HOLD_N of the flash memory.
Query is MAC Address is not configured (00:00:00:00:00:00). To configure the MAC address
  • What tool needs to be used to program Flash memory?
  • What file needs to be programmed into the flash?
  • Can it be programmed through JTAG, or does any other physical device need to be connected?
  • What physical hardware to be used to program?
  • In document 513655, there are many files. Which file needs to be used in iNVM?
Fikri_Intel
Hi Naveen_C,
Based on the inquiry, we will move to the appropriate team for assistance.
Fikri_Intel
CarlosAM_INTEL
Hello, @Naveen_C:
We received your request but we want to address the following consultation to understand your request:
Could you let us know all the information about the third-party CPU module that is related to the WGI210A Ethernet controller implementation?
We are waiting for your reply.
@CarlosAM_INTEL.
