Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
956 Discussions
Does I210-CS support Serial Flash Interface?
t-suzuki
I am using i210-CS device with an external flash in our custom board.
For now, I am trying to write configuration data to the external flash.
I refer to the document No.333016-011 "Intel Ethernet Controller I210 Datasheet"
and it indicates that i210 supports an external serial flash interface for storing product configuration information.
On the other hand, I saw the document No.335761-009 "Intel Ethernet Controller I210-CS/CL Datasheet"
that notices I210-CS/CL can be used to connect an external Flash only for development purpose.
-Why are there two datasheets (specific or no marks) for i210 device ?
-Does it mean that i210-CS device can store product configuration information only in an iNVM
and cannot use an external flash?
Caguicla_Intel
Hello t-suzuki,
Since your query involves custom board, please be informed that this will be best answered by our Embedded Connectivity Support team. We will help you to move this post to the designated team for further assistance.
Please feel free to contact us if you need assistance from Ethernet support team.
Crisselle C.
Intel® Customer Support
CarlosAM_INTEL
Hello, @t-suzuki:
You should compare section 1.3 (product overview section) of the cited datasheets to find the reasons to have those documents.
The information stated in section 1.4.5, on page 9 of the Intel Ethernet Controller I210-CS/CL Datasheet may answer your last question. This document can be found on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/335761
@CarlosAM_INTEL.
