Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
E810-cam2
kaos
Hi there,
Quick question, i have a custom design with E810 on board. Is there any guide how to program the external flash memory?
Cheers
Zigfreid_Intel
Hello kaos,
Thank you for posting on Intel Ethernet Communities.
We would like to confirm if you are using embedded controller for the E810? If so, please provide us the exact model of your mother board.
We would also like to ask what you meant by "I have custom design with E810 on board" and why would you be needing the information so we can provide an accurate information.
If you have questions or other clarifications please let us know so we can help you further.
Awaiting to hear from you soon, should there be no response from you, I’ll make sure to reach out after 3 business days. Thank you and have a nice day!
Zigfreid I.
Intel® Customer Support
kaos
Hi Zigfreid,
Thanks for the response, I have designed a board with E810-CAM2 and I do have the external FLASH(NVM) with SPI connected to BMC, so I was wondering what is the SPI FLASH image file that needs to be pre-loaded, so when the system powers up E810 can load the necessary information to E810 so processor can identify the device.
Cheers
Mustafa
Zigfreid_Intel
Hello kaos,
Your query will be best answered by our Embedded Connectivity Support team. We will help you move this post to the designated team for further assistance.
Please feel free to contact us if you need assistance from Ethernet support team.
Zigfreid I.
kaos
Hi Zigfreid,
That would be great if we can move it to Embedded Connectivity Support team, please let me know how can we do that as soon as possible please.
Cheers
Mustafa
CarlosAM_INTEL
Hello, @kaos:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
motorinnv
Hello @CarlosAM_INTEL
Can we get the same flash mage for E810-CAM1, which needed to be preloaded?
Thank you in advance!
Diego_INTEL
Hello @motorinnv,
I'm sharing the same response from the other forum, I hope it helps.
I have found the following document:
https://www.intel.com/content/www/us/en/download/19624/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapter-e810-series.html
Also, you can check document #618666 - Intel® Ethernet 800 Series Network Adapters NVM Update Instructions
@Diego_INTEL
