We are using the i226-LM for an embedded application with an ARM processor. We need to program the external flash. The latest EepromAccessTool (572162-eepromaccesstool-0.8.0.zip) does not include support for the i226. Is there a newer version or different tool that does?
I tried adding the i226 device IDs at the same places as the i225 device IDs, but got an error: "Enable Serial Flash Bit Interface timed out." when trying to dump from a NIC that was already programmed.
Andy
Hello @VideonAndy,
I looked internally and it seems that recompiling the tool by adding the device IDs from the datasheet may help to program the MAC address. You can check section 5.1.1.8 Device ID - 0x000D.
https://cdrdv2.intel.com/v1/dl/getContent/596659
链接已复制
Hello @VideonAndy,
We were able to get the tool working by adding the i226 device IDs. Thanks!
Hi @VideonAndy,
I have the same issue, would you be willing to share the modifications you made to add support for I226 in detail?
E.g. a patch showing which additions have to be made to which files.
Danny
@dannyL ,
See the attached patch that we used.
In addition, our controller was on PCI domain 1, so we needed this change:
--- a/PciEeprom.c
+++ b/PciEeprom.c
@@ -422,7 +422,7 @@ void CheckCommand(u16 LocationUnparsed)
// open the file that lists the devices connected to the PCI bus
// some systems may have it in a different place, so check both
- if(snprintf(temp, (size_t) sizeof(temp), "%s/0000:%.2x/%.2x.%x", DEVICE_LOCATION,bus,device, function) == sizeof(temp))
+ if(snprintf(temp, (size_t) sizeof(temp), "%s/0001:%.2x/%.2x.%x", DEVICE_LOCATION,bus,device, function) == sizeof(temp))
printf("Check Command error %s\n",temp);
Andy
Hi @VideonAndy,
Thank you very much for sharing the patch, the EAT is now able to recognize the I226 NIC.
Danny
Hi @Diego_INTEL ,
Sorry to comment on this old thread, however, I am trying to download the patch provided by @VideonAndy. For some reason, it seems the download link is disabled due to an ongoing virus scan (see screenshot). I have already tried with two different browsers, but the issue seems persistent.
Can you help me to download that patch?
Thank you!
Christoph
Hello @cbae,
Yes, I have the same result but I have it in my downloads folder from before, I will share it, I think this post from Andy is very useful.
Hello @cbae,
It seems the "Virus scan in progress ..." may be due to some recent change in the virus scanner, I have shared the file to your registered email address.
Hello @Diego_INTEL,
perfect, many thanks for your quick support! And thanks @VideonAndy for sharing this useful patch.
Best
Christoph
