Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
FM10K link issue
User1581302316066249
I'd like to know FM10K support 100Gbase-LR4.
100Gbase-SR4 is OK, but LR4 is failed.
Thanks in advance,
J. S. Kim
CarlosAM_INTEL
Hello, @User15813023160662497570​:
It is important to clarify that the 100GBase-SR4 mode is mentioned in sections 7.2, 7.7.1, and 12.9.1; on pages 302, 311, and 834 of the Intel(R) Ethernet Switch FM10000 Datasheet document # 333497.  The other mode is unmentioned on the cited document.
This document can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/333497.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@Mæcenas_INTEL​.
Hello, I’ve tested on the Intel reference system (FM10840 + Atom) I just want to know whether FM10K supports 100Gbase-LR4 or not. Thanks, J. S. Kim
CarlosAM_INTEL
Thanks for your reply.
It is important to clarify that the unmentioned information in the documentation of the Intel devices has not been tested or validated with them.
Due to this fact, the cited mode should be tested and validated by your own.
@Mæcenas_INTEL​.
