Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
915 Discussions
How identify i210-AT SDP Time Stamp Event issue
Thomas_tang
Hi all,
 A I210-AT chip defined with SDP0, the SDP0 is a input as PPS source.  I210-AT is embedded in a CPU module. The SDP function is configured as external time function. The PPS source is normally 2 square wave per second, each wave width is 500ms. According to the i210 datasheet, when the level change SYSTIM is latched into AUXSTMPL/H.
But in the igb driver, i found that sometimes more than twice interrupts per second. how to identify this root cause.
My observation is:
[ 3121.756892] igb_msix_other entry
[ 3121.758825] tsicr value 32
[ 3121.758830] timestamp 1593403118873225068
[ 3121.762955] sys timestamp 1593403118880067386
[ 3122.084124] igb_msix_other entry
[ 3122.086060] tsicr value 33                                                        <- this is an unexpected, more Time Stamp Event
[ 3122.086065] timestamp 1593403119200457212
[ 3122.090191] sys timestamp 1593403119207302983
[ 3122.256901] igb_msix_other entry
[ 3122.258841] tsicr value 32
[ 3122.258847] timestamp 1593403119373225940
[ 3122.262970] sys timestamp 1593403119380082562
[ 3122.756917] igb_msix_other entry
[ 3122.758856] tsicr value 32
[ 3122.758860] timestamp 1593403119873226820
[ 3122.762986] sys timestamp 1593403119880097499
igb driver info:
InceptioAGL:~# ethtool -i eth-ptp
driver: igb
version: 5.6.0-k
firmware-version: 3.25, 0x800005cc
expansion-rom-version:
bus-info: 0000:0b:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Any suggestion is thankful.
CarlosAM_INTEL
Hello, @Thomas_tang:
We want to address the following questions to understand the reported issue:
Could you please let us the procedure followed to obtain the driver related to the reported situation and where to find it?
Is this condition related to a specific version of the driver or does it happen with different versions? Please mention the tested versions and the results with each one.
We are waiting for your answer.
@CarlosAM_INTEL.
