Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
956 Discussions
i210-IT ethernet controller SMBus
dpelaez
Can the SMBus of the i210-IT ethernet controller be connected to an I2C interface?
Jaime_Lizarme
Hi Diego,
It might be possible to interface the SMBus with I2C; however, we don’t have any guidelines about this implementation available.  You can use the following documents as references:
https://www.mouser.com/datasheet/2/612/i210_ethernet_controller_datasheet-257785.pdf
https://www.dmtf.org/sites/default/files/standards/documents/DSP0237_1.2.0.pdf
Jaime L.
