Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
914 Discussions
How to change Inter Frame Gap(Inter Packet Gap) of I350 controller
MHLee
I'm trying to change from default 8 bytes IFG value to 12 bytes.
Anyone who give me a way to change this value ?
I found that it is not possible to change IFG through Windows Driver setting thruogh googling.
It seems like to change IFG through lanconf utillty but lanconf utility can change IFG only temperary.
I think Transmit IPG Register - TIPG (0x0410; R/W) must be set via EEPROM but I can't find the TIPG offset on EEPROM map.
Thank you.
Yogaeasvaran
Greetings MH Lee,
Thank you for Contacting Intel Customer Support.
We are currently checking information upon your request.
We will get back to you the soonest once we found details and information from our resources.
Yogaeasvaran
Yogaeasvaran
Greetings MH Lee,
Thank you for contacting Intel Customer Support.
These is the information that you have requested, and I have attached the link:
( https://cdrdv2.intel.com/v1/dl/getContent/333171?explicitVersion=true)
I350 datasheet > go to Topic 8.12.3 > under Transmit IPG Register - TIPG (0x0410; R/W) page 534
You can identify the changes of initial values for the Inter Packet Gap.
If you have any further questions or queries, please kindly let us know.
Thank You & Regards,
Yogaeasvaran
MHLee
Thank you for your reply.
I have already read this information on I350 datasheet and I’d like to know how to set the value that I want to power on default value.
I have changed the value I want through “lanconfw64e.exebut it was temporary.
I think it must be implemented some kind of changing EEPROM image.
MH Lee
Yogaeasvaran
Greetings MH Lee,
As this is a design related question, you will need to go through IPS or the embedded community.
Please post this question to embedded community thread as link below:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Yogaeasvaran
Yogaeasvaran
Greetings MH Lee,
Regarding your case number 06007876, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Yogaeasvaran
Yogaeasvaran
Greetings MH Lee,
We will move this thread to embedded community for you to post your queries for assistant.
Yogaeasvaran
CarlosAM_INTEL
Hello, @MHLee:
We received your requests but, could you please confirm if this forum is related to the stated in the following website created by you?
https://community.intel.com/t5/Embedded-Connectivity/How-to-change-Inter-Frame-Gap-Value-from-default-8-bytes-to-12/m-p/1534044#M4767
We are waiting for your answer.
@CarlosAM_INTEL
