Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
How to change Inter Frame Gap Value from default 8 bytes to 12 bytes ?
MHLee
I have been using I350 controller card with no problems under Windows 10.
But now, I have an issue that is required 12 bytes Inter Frame Gap(or Inter Packet Gap) for remote switch hub.
I have reviewed I 350 data sheet and found Transmit IPG Register - TIPG (0x0410).
I tried to read this register value and checked the default value via "lanconfw64e.exe".
But I couldn't find any way to set the change value on POR(Power On Reset) value.
I think this value might be implemented to EEPROM image but I couldn't find any from EEPROM map.
Could you give me an advice on this ?
Thank you.
CarlosAM_INTEL
Hello,  @MHLee:
We received your consultations, but we want to address the following questions to understand them:
Could you please confirm if the device related to this situation has been designed by you or a third-party developer? In case it is a third-party device, please let us know the name of the manufacturer and the part number of the device.
Could you please confirm if this situation is related to an Intel Ethernet Controller, NIC card, or adding card? Please mention the name of the manufacturer and part number.
Where do you purchase the device related to your requests?
We are waiting for your clarification.
@CarlosAM_INTEL.
MHLee
Hello Carlos,
Thank you for your reply.
The NIC card is XMC module by designed Concurrent Technologies.
I atteched the product link below.
XM 515/x24 - Gigabit Ethernet XMC Module - Concurrent Technologies (gocct.com)
We are representative of Concurrent Technologies in Korea.
MHLee
CarlosAM_INTEL
Hello, @MHLee:
Thanks for your reply.
We sent an email to the address related to this account with information that may help you.
@CarlosAM_INTEL.
