Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
How to change the I210 in 1000M Mbps Full Duplex
ZisGe
I burn the image into the I210. And reset the power, I find it is running in 100M mode, not the 1000M.
---> igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX
How to set the 1000M full duplex??
CarlosAM_INTEL
Hello, @ZisGe​:
You should refer to the FSD Bits information stated in chapter 6.8.6.1, on page 234 of the Intel(R) Ethernet Controller I210 Datasheet document #333016 that can be found on the following website:
https://www.intel.com/content/www/us/en/embedded/products/networking/i210-ethernet-controller-datasheet.html
@Mæcenas_INTEL​.
CarlosAM_INTEL
Hello, @ZisGe​:
@Mæcenas_INTEL​.
ZisGe
