Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
I210 connect to switch
bweip
I use the I210 on nvidia xavier platform and I connect I210 to switch chip(KSZ9477),  and the KSZ9477 has its on driver for linux. Does it have an effect on I210? like the boot sequence?
CarlosAM_INTEL
Hello, @bweip​:
Based on your previous message, could you please clarify if the Intel® Ethernet Controller I210 is used on a third-party implementation or in a design developed by you?
Could you please clarify if this forum is related to the ones stated on the following websites?
https://forums.intel.com/s/question/0D50P00004ddmnESAQ/which-image-should-i-choose-for-eepromarmtool
https://forums.intel.com/s/question/0D50P00004ddpQhSAI/eepromarmtool-only-can-flash-i210-for-one-time-than-it-always-faild-
We are waiting for your answer to these questions.
@Mæcenas_INTEL​.
bweip
yes, it is three problems we met on our own board: choose image, flash image, driver.
CarlosAM_INTEL
Hello, @bweip​:
Thanks for your reply.
We suggest that your schematics and layout implementation should be verified by Intel following the procedures stated on the following website:
https://edc.intel.com/Tools/Design-Review/Default.aspx
@Mæcenas_INTEL​.
