Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
919 Discussions
How to know the value of register GLTLAN_MIN_MAX_PKT for 710 NIC
mzhan017
Hello, I'm checking the document of https://cdrdv2-public.intel.com/332464/332464_710_Series_Datasheet_v_4_1.pdf
And found following statement "A single send packet or large send segment that is not between min / max sizes defined in the GLTLAN_MIN_MAX_PKT register.";
Would like to know if i40e support to read this register?
or if any default value for this register?
Mark
CarlosAM_INTEL
Hello,  @mzhan017:
We received your request, but we want to address the following questions to understand them:
Could you please confirm if the device related to this situation has been designed by you or a third-party developer? In case it is a third-party device, please let us know the name of the manufacturer and the part number of the device.
Could you please confirm if this situation is related to an Intel Ethernet Controller, NIC card, or adding card? Please mention the name of the manufacturer and part number.
Where do you purchase the device related to your requests?
We are waiting for your clarification.
@CarlosAM_INTEL.
mzhan017
We have the lab setup with HP Gen10 Server.
5d:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
DeviceName: Embedded FlexibleLOM 1 Port 1
Subsystem: Hewlett-Packard Company Ethernet 10Gb 2-port 562FLR-SFP+ Adapter
I can confirm this situation is related to Intel. As the document is provided by Intel: https://cdrdv2-public.intel.com/332464/332464_710_Series_Datasheet_v_4_1.pdf
The document has following statement "A single send packet or large send segment that is not between min / max sizes defined in the GLTLAN_MIN_MAX_PKT register.";
Mark
CarlosAM_INTEL
Hello, @mzhan017:
Thanks for your reply.
We cannot find the answers to our previous questions. However, we are going to address the following questions to understand this forum:
Are you referring to the information stated on the following website when you talk about the i40e?
https://www.intel.com/content/www/us/en/download/18026/intel-network-adapter-driver-for-pcie-40-gigabit-ethernet-network-connections-under-linux.html
Is the Ethernet Controller X710 related to the reported situation installed in the HP Gen10 Server Motherboard, or it is a Network Adapter, NIC Card, or Adding Card like the ones mentioned on the following website?
https://www.intel.com/content/www/us/en/products/details/ethernet/700-network-adapters/x710-network-adapters/products.html
Where do you buy the device related to the Ethernet Controller X710? What is the brand of this device?
Please let us know the information that should answer the previous questions.
@CarlosAM_INTEL.
