Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
Intel USB 3.1 eXtensible-Hostcontroller
Erido
I have connected a second monitor to the USB 3.1 port on my HP EliteBook 850 G5. Everything worked fine at first. However, when I remove the plug from the USB 3.1 port and plug it back in, the monitor no longer receives a signal. I then have to switch off the laptop and reset the USB 3.1 port by pressing the power button for approx. 30 seconds
(I found this in a forum). What is the problem or is there a driver from Intel that solves this problem?
The driver on my laptop is from Microsoft (driver version: 10.0.22621.2506).
Diego_INTEL
Hello @Erido,
You may try running the driver support assistant but it seems this is an old processor.
https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html
Maybe using a multiport device can help by not having to remove the plug.
@Diego_INTEL
NeMo-1
I'm sorry that I don't have a OP to quote however from memory I am nearly certain that this is a UEFI firmware bug and whether it's Intel or WHQL signed drivers eXtensible Host Controller despite saying it's a 3.0 controller I can assure you that this device is properly controlling the USB 3.1 gen2 monitor at Intel Spec 3.2.
Unfortunately the general consensus is that it's a UEFI firmware bug having just last minute launched the fancy new USB capabilities and these UEFI are a slightly outdated version of what is shipping now the BIOS will choke every time the USB is reattached as far as I know there's no updates available the community solution that 'everyone' more less is accepting as solved is to–
"I then have to switch off the laptop and reset the USB 3.1 port by pressing the power button for approx. 30 seconds"
--this is both the workaround dirty fix that you posted as well as community solution #1--
That's necessary because to make the monitor connected to UEFI video there's a bios variable that gets set to the NVRAM and the UEFI of this first generation tech was never programmed with code to allow USB Controller to modify the NVRAM variables representing each video device in UEFI prior to this chipset could never reassign them automatically after reconnected it gets a new disiplay variable but the graphics are still pointing to the now detached and reattached removable display.
#2
There's an extremely moderate to moderate-extreme difficulty actual real solution but most people are far too lazy and uncomfortable working with anything lower than Windows but because this is not a windows issue either we have to go to the BIOS NVRAM itself. When you are running Windows or another UEFI OS the UEFI shell is usually accessible via boot manager, various escape signals, but Windows is fully controlling the displays and GPUs by taking over control of those things with aforementioned drivers. In my personal opinion RS232 UART-to-USB or UART-to-JTAG serial port console or virtual emulated console UEFI drivers for WHY¿
TO CONTINUE TO ACCESS THE UEFI SHELL POST-SECONDARY BOOT WHILE WINDOWS IS STILL CONTROLLING THE MACHINE because you'll have to manually name every display adapter that you use USING UEFI SHELL CODE and requiring to be aware of device vendor's VERY SPECIFIC MEMORY ADDRESSES that are not going to be the same for a Lenovo as a ASUS though maybe identical Intel 945's as THESE VARIABLES ARE SOMETIMES blocked FROM END USED, sometimes found on some forum device builder message boards by the system manufacturer, sometimes an option right in the bios setup phase like click with your mouse exposed, most people actually have at the address space to look at what is in memory and figure it out it is possible to Turn-Key provision a way to switch video intelligently.
Basically the very next generation of bios for newer hardware took care of it naming every adapter fb0 fb1 fb2 etc. and so forth and the USB controller spec updates was a rushed release so you unplug the monitor and relocate and when you plug in the monitor again it's created fb3 except fb2 still exists! The conflict and yes the reboots but yeah-
Just so you know if you're a contractor and someone is demanding perfect pinbutton function with a machine based on this chipset it's doable like not impossible at all there's a couple ways you could go about it
WARNING if you know your way around a UEFI bios shell and do manage TO create MEMORY RESIDENT static device names for multiple displays you'd just need to set the bit to memory to manually initialize the specific graphics adapter and you want enabled and attache all the USB  hot plug no problem it's assising displays identifiers like Linux assigns dev files sda sdb sdX ... except it's in the freaking BIOS and not about storage
So #2 in summary is the capability is there to statically assign displays TO AVOID COLD REBOOT AND the dummy way of enumerateting for the actual MUX devices BUT now that you will no longer be concerned with rebooting you should know after reprogramming NVRAM if you cold restart for any reason ALL video is permanently discoupled THINK BLACK SCREEN OF DEATH so IF YOU NEED TO BE HOT PLUGGING THIS MONITOR PEACE OF CAKE BUT ONCE YOU GO THAT WAY it's not easy to just reset your firmware and get video on boot THAT'S JUST IF YOU REBOOT WITH THE MONITOR NOT ATTACHED could even write a usermode driver and bake a gui into your Sysprep to toggle the ways displays enumerated by UEFI improvised modes or just basically the additional logic that's in the windows and the Intel Chipset but missing from UEFI bios probably stubs hiding partial implementations.
Of course #3 sweet 3 buy a newer computer mfg about literally just a year later or maybe some experimental community homebrew BIOS like flash the EEPROM and compile yourself something cobbled from TianoCore sunset.
That's it that's all I never post more than two threads daily hope maybe I helped someone could be hosting a mri medical the trolls don't know could always be important?!
NeMo-1 has not configured a signature
MRGCAV
I understand the premise but do not have the skills to solve the problem.
     I have an Asus GL702VS, Win 10 Pro, Laptop. I am trying to connect a New  ASUS PA32UCDM 4k 32" monitor via a Thunderbolt cable as a third monitor.
The laptop is TH3. I have two HDMI Monitors connected and they work fine.
Hardware ID is:
PCI\VEN_8086&DEV_15C1&SUBSYS_11112222&REV_01
PCI\VEN_8086&DEV_15C1&CC_0C0330
When I connect a regular USB non video cable to the TB port, the port works well for data only.
PROBLEM: When I connect up the one 4K PA32UCDM monitor via a thunderbolt cable to the same laptop port, all the screens freeze. The 4K monitor is detected but receives no video.
TH drivers and all other drivers are up to date. According to all specifications I can connect up to 6 TB monitors.
I do not what the problem is or how to diagnose it.
How can I test a TB3 port ?
I am uncertain what driver I need or if this is a UEFI bios problem or not.
Need help
[email protected]
n_scott_pearson
You need to install the Chipset Device Software (a.k.a. INF update) package to resolve and configure this device properly. This package should be on the downloads page provided by your motherboard manufacturer.
Hope this helps,
MRGCAV
Hello,I said      "TB drivers and all other drivers are up to date."  If it were a simple Driver update, I would not be asking for help here.
Asus provides no out of warranty support for anything including the correct driver.
That is where the issue starts to get complicated.
Some posts say its a problem in the BIOS.  I am not sure what to believe.
n_scott_pearson
Sorry, I thought you were saying that the USB Extensible Host Controller was unresolved. Regardless, in case you are unaware, you should be running the Chipset Device Software package installation even if appears that all devices are showing up as resolved and up to date after Windows Update/Setup runs.
Have you verified that Asus hasn't released a Firmware update for this TBT controller? Are you aware of the oft-necessary interaction with the Thunderbolt Control Center app?
MRGCAV
Hello
In my case, at least it is unresolved.   Which  Chipset Device Software package installation ?  Version ?   If its the one currently on the ASUS Website then I am running it.
When I set up the OS I downloaded and installed all Asus drivers. Then did Windows updates, In that order.
    I am aware that Intel gave the TB issue to ASUS to resolve and Asus probably did not resolve the issue,  I can find no confirmation of anyone who had resolved this issue. I read about several suggested cures but nothing definite.   I would think someone else would of experienced this problem and that I can confirm that a few owners have.  Some say it is a BIOS issue others say it is a Driver issue. But nobody says they definitely have solved this problem.... That I can find.
The latest cure I have heard of, involves an TB controller app (probably your Thunderbolt Control Center app) , Which I have downloaded but I can not find the associated driver.  Unless I am doing something wrong or assuming I need the associated driver to work with the app. Nor do I know how the app works.
Asus discontinued TB Support and never seemed to publish the associated driver.    Nothing I have read is specific enough to be instructional.
I have been collecting every TB3 driver I can find.
  I do not want to try drivers at random for fear of Bricking my only computer.
Your assistance is much appreciated.
n_scott_pearson
Ok, No, your first picture shows the controllers all configured and running properly, so that's not the issue.
[Aside: Some notes for the future,
  • The Chipset Device Software package is often referred to as the INF Update package because most chipset devices have their drivers inbox with Windows and only need to be optimally configured, which is done via an .INF file.
  • Very important: You should always, always install the Chipset Device Software package and reboot BEFORE installing any other Intel driver packages. There is (albeit anecdotal) evidence that points to there being dependencies between packages.
  • If you ever think that you might have an issue with a Chipset device, you can rerun the Chipset Device Software package and fix it up. In this case, you need to extract the ZIP file to a temp. folder and then run the included installer with command line "SetupChipset -overall". This flag tells the installer to install support for and configure every device, regardless of whether done previously.
  • Here is order you should install the chipset-related drivers in:
Intel INF Update Driver
Intel Management Engine Interface
Intel Serial IO GPIO Driver
Intel Dynamic Platform and Thermal Framework Driver
ThunderBolt
End of Aside.]
Ok, all that said, we'll have to look elsewhere. I have some thoughts, but need more information from you to see whether they are possibilities.
First of all, unplug the secondary monitors (those connected to the µDP and HDMI ports) and then try connecting the monitor via the TBT interface. If this works, it tells me that you are likely tripping over the fact that all displays are 'owned' by the processor's iGFX engine - and this engine will support a maximum of three displays, not the four that you want (unless you can disable the embedded display).
Exhausting that possibility, I will need more information on your Windows installation. Please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and attach this text file to the response post.
