Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
I210 eepromARMTool: Check Command open to write error
bweip
I use I210 on Nvidia Xavier platform. I want to configure it.
There is an error: ​Check Command open to write error.
the resault:
nviida@ubuntu:~/eepromaccesstool-0-7-9$ sudo ./EepromAccessTool   Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool Version 0.7.9 Provided under the terms of a CNDA. Do Not Distribute. Copyright(C) 2017-2019 by Intel(R) Corporation NIC BUS DEV FUN Silicon Memory Type Present === === === === ===== ====================== Check Command open to write error 1 1 0 0 I210 INVM+FLASH nvidia@ubuntu:~/eepromaccesstool-0-7-9$ sudo ./EepromAccessTool -dump -NIC=1   Intel(R) EEPROM Access Tool NVM/OTP Programming Example Tool Version 0.7.9 Provided under the terms of a CNDA. Do Not Distribute. Copyright(C) 2017-2019 by Intel(R) Corporation Check Command open to write error Found an NVM
bweip
solved. I edit the source file. the path of pci device is wrong.
bweip
