Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
954 Discussions
I210 iNVM programming issues
MNoone
I have a board where I would like to use an I210 to connect my CPU to an Ethernet switch over SGMII. The board currently has a 4Mbit SPI flash connected to each I210, a Microchip SST25VF040B-50-4I-QAF-T, but for the next revision I think I'll switch to a 16Mbit SPI flash, the Macronix MX25V1635FZNI.
I am running Linux. I need to program the I210's iNVM with MAC address and also (I think) tell it to use SGMII. I ran this command:
sudo ./eeupdate64e /nic=1 /file=I210_Invm_SerDesKX_NoAPM_v0.6.txt /invmupdate /mac=524658000001
I did get one error "Error: Connection to QV driver failed - please reinstall it!"
And while the NIC no longer shows up as unprogrammed when I run LSPCI, if I run ip link it shows as having all zeroes for the mac address. This remains the same after a restart.
Any feedback on what I am doing wrong? Do I need to figure out the QV driver issue?
Further - is the iNVM one time programmable? So if I get this wrong do I have to replace the IC?
Lastly is the I210_Invm_SerDesKX_NoAPM_v0.6.txt file correct for SGMII or is that only for 1000BASE-KX? That is from "513655_I210_I211_Production_images". I am using the eeupdate64e tool from Quartzville Tools_745290.
Thank you for your help!
Fikri_Intel
Hi MNoone,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue. Upon checking, the Ethernet controller programming falls under another team. To ensure you receive the most accurate and specialized assistance, I will be moving your thread to the appropriate team that is better equipped to handle your specific concern.
The correct team will reach out to you and address your inquiry while providing you with the assistance you need.
Fikri_Intel
