Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
957 Discussions
Intel I210 and support memory?
JPosp
Hi.
I use intel I210 for 1GB ethernet. And I'd like to use the IS25LP128 memory. Will this memory work with this chip?
CarlosAM_INTEL
Hello, @JPosp​:
We suggest verifying with the manufacturer of the cited device that it fulfills with the requirements stated in sections 1.4.4 and 11.8, on pages 10 and 801 of the Intel(R) Ethernet Controller I210 Datasheet document # 333016. This document can be found at the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-ethernet-controller-datasheet.pdf
We hope that this information may help you.
@Mæcenas_INTEL​.
Mike_Intel
Hello JPosp,
Before we proceed, let me clarify first if you are going to design or integrate the Intel I210 to a board with the IS25LP128 memory? Kindly explain further on how you will implement this.
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
JPosp
Hi MikeL.
I create my own album. The memory connection to the I210 is shown in the figure. Is it possible to use this memory with this connection?
Mike_Intel
Hello JPosp,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Michael L.
CarlosAM_INTEL
Hello, @JPosp​:
@Mæcenas_INTEL​.
JPosp
Thank you for your advice Maecenas_INTEL. I read a datasheet comparing hex instructions and I think everything will be fine. 👍
