Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
Intel i210 IT NIC card support on ARM platform
RRahm1
I am trying to work with intel i210 IT NIC interface card on ARM platform for AVB development using modified IGB AVB driver provided by OpenAvnu.
This card is working fine on Linux based PC with modified IGB AVB driver provided by OpenAvnu community. This card has PCIe x1 connecting interface.
Please find the below link for more product description.
Please find the link to modified IGB AVB driver maintained by OpenAvnu.
https://github.com/AVnu/OpenAvnu/tree/master/kmod/igb OpenAvnu/kmod/igb at master · AVnu/OpenAvnu · GitHub
I wanted to know whether this NIC card with IGB AVB driver compatible on ARM platform?
Whether this driver is architecture dependent works only on X86 arch. Basic ping functionality is also not working with modified driver on ARM platform.
Please find the below link of product:
https://www.amazon.in/Intel-I210-T1-PCI-Express-Ethernet-Desktop/dp/B07121WCKJ Amazon.in: Buy Intel 9204CT Chip I210-T1 Single Port PCI-Express x1 Ethernet Desktop Adapter Online at Low Prices in Ind…
Riyaz
Adolfo_S_Intel
Hello riyaz
We are researching about this case, and we will provide more information as soon as possible.
Adolfo Sanchez
CarlosAM_INTEL
Hello, riyaz:
In order to be on the same page, could you please tell us if your consultation is associated with the Intel 9204CT NIC card?
Please let us know the requested information.
Carlos_A.
RRahm1
Hello Carlos_A:
Yes, query is associated with Intel 9204CT based i210 NIC card which, we are trying to use on ARM platform with modified IGB driver for AVB.
Riyaz
CarlosAM_INTEL
Hello, riyaz:
Thanks for your update.
We suggest you address this thread to the https://communities.intel.com/community/tech/wired Intel Wired Ethernet Forum, which is the proper channel to give you support related to the device associated with this condition.
We hope that this information may help you.
Carlos_A.
