Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
i210AT (on thunderbolt) how to change the PCIe "subsystem vender ID" and "subsystem ID"
ATsai15
hello
I designed a Thunderbolt dock with i210AT LAN. I want to know how to modify the "subsystem vender ID" and "subsystem ID." I tried to run lanconfw64e.exe but cannot save.
Appreciate your help.
CarlosAM_INTEL
Hello, Anderson.Tsai:
The information that may help you is stated in the answers to the questions 2.21, 2.15, 2.14, 2.16, 2.23, and 2.25; on pages 9 and 8 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document # 335346.
We hope that this information may help you.
Carlos_A.
ATsai15
Dear Carlos
in section 2.23
Not all fields in the image are protected. Fields that are normally subject to change by the OEM, such as
the MAC address, PCI subsystem ID fields and LED customizations, can be changed without invalidating
the digital signature.
I can program the MAC address. But I don't know how to change the PCI subsystem ID field. Do I need pull down the pin12 to unlock the security?
Anderson
ATsai15
hi
I already knew the answer. Just use lanconf to change the offset 0xC.
thsnks
CarlosAM_INTEL
Hello, Anderson.Tsai :
Thanks for your update.
We are glad that you have shared your solution to your problem.
Please do not hesitate to contact us if you have any question related to Intel Embedded products. We will be more than glad to help you.
Carlos_A.
