Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
Only using 1 channel of the X557-AT2, what is the current consumption?
kh12
I am using an x557-at2 ethernet controller, but only need to use one of the channels. I am trying to design the power rails for the device, so I am mainly looking at the maximum currents which in the case of this device , the 0.83V rail goes up to 8A. Since I am only using one channel would it be fair to design the rails to 50% of the maximums? If not, could you give me some guidance on what current values I should be using to design the power rails? Thank you.
p.s. I realize x557-at exists, however it is not easily purchaseable right now and we therefore need to use the dual channel one.
-Karla
Diego_INTEL
Hello @kh12,
This forum is for Embedded products, but in my opinion, the AT uses exactly the half as the AT2, 4 A, and AT4 16 A, it seems that 4 A is the maximum current that may be assigned to each port, seems good to design for one port and also, disable one port from the NVM image.
@Diego_INTEL
kh12
Diego_INTEL
Hello @kh12,
Well, in Ethernet forum they should try to help, if not there is our IPS service too.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
@Diego_INTEL
