Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
947 Discussions
Problem with interfacing i210IS to BCM53134P
DVais
the broadcom part identify link but the i210 does not, see ethtool response:
    Supported ports: [ FIBRE ]
    Supported link modes: 1000baseKX/Full
    Supported pause frame use: Symmetric
    Supports auto-negotiation: Yes
    Supported FEC modes: Not reported
    Advertised link modes: 1000baseKX/Full
    Advertised pause frame use: Symmetric
    Advertised auto-negotiation: Yes
    Advertised FEC modes: Not reported
    Speed: Unknown!
    Duplex: Unknown! (255)
    Port: FIBRE
    PHYAD: 0
    Transceiver: internal
    Auto-negotiation: on
    Supports Wake-on: pumbg
    Wake-on: g
    Current message level: 0x00000007 (7)
                drv probe link
    Link detected: no
Mike_Intel
Hello DVais,
Before we proceed, can you confirm if you are the one who integrated the Intel® Ethernet Controller I210-IS to BCM53134P?
Please tell us when can we expect an update on this. If there is no reply, is it okay if make a follow up after 3 business days?
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
DVais
Hi Mike,
I am interfacing the i210 with the BCM part.
I am asking about your recommendation of what to do with the bad response of the i210 and make the connection operative.
We need your recommendation ASAP and then you can follow up after 3 business days.
Danny V
Halo-Analytics
Mike_Intel
Hello DVais,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Michael L.
DVais
meanwhile we made some signal measurements, the broad part is issuing active signals while the i210 does not.
also tried to set different parameters with ethtool but it failed with error message. reading counters return all 0 but some other fixed parameters are read correctly.
CarlosAM_INTEL
Hello, @DVais​:
Could you please clarify if this situation happens on your design or a third- party design?
In case that it is a third-party device, could you please inform the name of the manufacturer, its model, the part number, and where its documentation is stated?
On the other hand, could you please let us know how many units of the project related to this circumstance have been manufactured? How many are affected? Could you please give the failure rate? Also, could you please list the sources that you have used to design it and if it has been verified by Intel? Could you please let us the procedure that you have followed to determine this issue?
Could you please give pictures of the top side markings of the Ethernet controllers?
We are waiting for your reply to these questions.
@Mæcenas_INTEL​.
DVais
Thanks for the fast and detailed response, issue resolved by reprograming.
CarlosAM_INTEL
Hello, @DVais​:
Thanks for your reply.
We are glad that your problem has been solved.
Please do not hesitate to contact us again if you have more questions related to Intel Embedded products.
@Mæcenas_INTEL​.
